help with installation
01 Aug 2024 12:07 #306602 by cnbbom
help with installation was created by cnbbom
Hello everyone!
I intend to learn how to use LinuxCNC and I immediately saw an ISO 2.92 RT.
However, I use LPT and a PCI Express. What I need is a step-by-step guide to installing RTAI with the newest ISO possible or if this ISO can be configured. I don't really know anything about Linux, but in tests with the pendrive simulator I saw that the machine ran much better than Mach3 even though it wasn't RTAI.
I'm counting on my friends' help.
  • Platinum Member
  • Platinum Member
01 Aug 2024 12:12 #306603 by Cant do this anymore bye all
The following user(s) said Thank You: cnbbom
01 Aug 2024 12:55 #306607 by cnbbom
Replied by cnbbom on topic help with installation
As far as I understand, I have already downloaded the files but what commands should I use to install?
  • Platinum Member
  • Platinum Member
01 Aug 2024 13:13 #306609 by Cant do this anymore bye all
Replied by Cant do this anymore bye all on topic help with installation
forum.linuxcnc.org/9-installing-linuxcnc...r-2-9?start=0#304599
Start with the kernel packages, then I think there are some modules then finally the Linuxcnc packages. Best thing is to read completely read through both threads linked in the previous threads.
01 Aug 2024 14:11 #306621 by cnbbom
the second option worked but the first one didn't
1To install from a fresh Debian 12 with NO LCNC installed yet, just use: sudo dpkg -i (package name here without brackets) for each deb and reboot. Choose the RTAI kernel in Grub, enjoy.
2To install on Debian 12 with linuxcnc-uspace already installed use : sudo apt purge linuxcnc* and wait for apt to completely remove every trace of LCNC.
Then follow the instructions for a fresh Debian 12 install above.
01 Aug 2024 14:14 - 01 Aug 2024 14:15 #306622 by cnbbom
apt purge linuxcnc*
Reading package lists... Done
Building dependency tree... Done
Reading status information... Done
The package 'linuxcnc' is not installed, so it will not be removed
0 packages upgraded, 0 newly installed, 0 to be removed, 0 not upgraded.
Last edit: 01 Aug 2024 14:15 by cnbbom.
01 Aug 2024 15:32 #306627 by cnbbom
I can now say what condition I am in
  • Moderator
  • Moderator
01 Aug 2024 15:48 #306631 by tommylight
Replied by tommylight on topic help with installation
Do a new full install and start over.
Never use root or SU to install stuff as everything will be installed in the root folder and nothing will work as a normal user, always use sudo.
LinuxCNC will refuse to run as root due to having full hardware control and stopping misuse.
01 Aug 2024 16:15 #306635 by cnbbom
Before seeing your post, that's what I did, so I was right to do a new installation
Thank you, now I need to know something, are there 4 files, should you install all 4 or just one?
linux-headers-5.4.279-rtai-amd64_5.4.279-rtai-amd64-1_amd64.deb
Arquivolinux-image-5.4.279-rtai-amd64_5.4.279-rtai-amd64-1_amd64.deb
Arquivolinuxcnc_2.9.2_amd64.deb
Arquivortai-modules-5.4.279_5.3.3-linuxcnc-delta_amd64.deb
01 Aug 2024 16:18 #306636 by cnbbom
Your avatar is scary, but you look like a good person!
I'm able to understand things
Time to create page: 0.139 seconds
