LINUXCNC on Raspberry PI 5 2GB
11 Sep 2024 10:56 #309892 by WarcoVMC
LINUXCNC on Raspberry PI 5 2GB was created by WarcoVMC
I have a RPI 5 that will not install from the LinuxCNC 2.9.2 Raspberry Pi 5 OS based on Debian Bookworm i mage.
The RPI 5 is only the 2GB version. Would this be the problem?
THis RPI 5 works ok from the nomal Raspberry PI imager program
11 Sep 2024 13:01 #309896 by rodw
Replied by rodw on topic LINUXCNC on Raspberry PI 5 2GB
Try using Balena Etcher  to burn your image. There is an issue with the pi imager
11 Sep 2024 15:12 #309913 by elovalvo
Replied by elovalvo on topic LINUXCNC on Raspberry PI 5 2GB
The following user(s) said Thank You: WarcoVMC
11 Sep 2024 21:59 #309944 by WarcoVMC
Replied by WarcoVMC on topic LINUXCNC on Raspberry PI 5 2GB
I think I tried Balena Etcher
But yor link above work. You are a Star
I did read some were that the 2 GB RPI 5 has a new die revision so I thought this may have been an issue somehow.
Many thanks. Martin
The following user(s) said Thank You: elovalvo
Time to create page: 0.152 seconds
