LinuxCNC 2.9.4 Released
  • rodw
  • rodw's Avatar Topic Author
  • Platinum Member
  • Platinum Member
28 Jan 2025 00:43 #319967 by rodw
LinuxCNC 2.9.4 Released was created by rodw
Over the weekend Andy released linuxcnc 2.9.4
To upgrade an existing bookworm release running version 2.9 all you need to do is to type
sudo apt update
sudo apt upgrade
And go and have a cup of coffee
The ISO has also been upgraded for new installs on Intel X64 hardware. Grab it from the LinuxCNC downloads page.
The raspberry pi has not been upgraded but I've roped in Cornholio to help build images for release via linuxCNC repository so stay tuned.
Please join me in thanking Andy for his tireless work :clap:
The following user(s) said Thank You: bevins, pommen, Aciera, my1987toyota, royka, onceloved, am-i-go, Unlogic, Cant do this anymore bye all, Taelman and 1 other people also said thanks.
  • Platinum Member
  • Platinum Member
28 Jan 2025 01:59 - 28 Jan 2025 02:06 #319970 by Cant do this anymore bye all
Replied by Cant do this anymore bye all on topic LinuxCNC 2.9.4 Released
Big thanks to Andy.
Another to Rod for all his hard work.
And the rest of the devs, those that found bugs and everyone else involved.
On a personal note I'd like to give a big thanks to royka for being so patient with myself regarding the kernel config & patching. Cheers mate.
Rpi5 image tested, I'll test the Rpi4 this arvo and get it up. For those that are interested the Rpi images have the SPI interface enabled by default, no need to edit config.txt and reboot.
Last edit: 28 Jan 2025 02:06 by Cant do this anymore bye all.
The following user(s) said Thank You: bevins, rodw, royka, am-i-go
  • Moderator
  • Moderator
28 Jan 2025 12:29 #319987 by tommylight
Replied by tommylight on topic LinuxCNC 2.9.4 Released
Pinned.
Thank you.
  • Platinum Member
  • Platinum Member
29 Jan 2025 02:44 #320036 by Cant do this anymore bye all
Rpi Images are up now.
Once again thanks to Andy for making it all happen.
The following user(s) said Thank You: bevins, tommylight, Aciera, royka
  • rodw
  • Platinum Member
  • Platinum Member
29 Jan 2025 04:46 #320044 by rodw
Replied by rodw on topic LinuxCNC 2.9.4 Released
Not to mention thanks to Cornholio for building the rpi images and including his special features. And installing  the 6.12 rpi kernel to get the most out of the rpi5
30 Jan 2025 14:00 #320146 by bevins
Replied by bevins on topic LinuxCNC 2.9.4 Released
Nice job guys....
  • Moderator
  • Moderator
10 Mar 2025 20:30 #323631 by tommylight
Update the kernel to at least 6.8.n, preferably 6.12.n.
  • rodw
  • Platinum Member
  • Platinum Member
11 Mar 2025 01:26 #323646 by rodw
The default kernel is whatever is in Bookworm. You need to wait for Trixie to get a later kernel (6.12 I think) The debian installer gets the kernel version from the host PC when its built.
  • Moderator
  • Moderator
11 Mar 2025 02:25 #323649 by tommylight
Not sure, but i think RT 6.8.n was installed last i used Debian 12, so ....
11 Mar 2025 02:38 #323650 by unknown
Replied by unknown on topic LinuxCNC 2.9.4 Released
Sounds about right for Bookworm.
Trixie for ARM might be an issue as libgpiod version Trixie uses will require some effort with the hal_gpio driver, maybe a rewrite.
Andy is the expert on this, pretty sure he made a note of this some time ago.
Apart from that the ARM image is fine.
Time to create page: 0.338 seconds
