LinuxCNC 2.9.4 Released
11 Mar 2025 02:42 #323651 by unknown
Replied by unknown on topic LinuxCNC 2.9.4 Released
Another thing to think of, what happens when X11 support is dropped in favour of Wayland ?
The GUIs that rely on X11 libs.
Tho it received no interest apart from 2 forum members I managed to build a Devuan ARM image, no systemd and their CoC is fair to all, basically just don't be a dick to anyone.
  • rodw
  • rodw's Avatar Topic Author
  • Platinum Member
  • Platinum Member
11 Mar 2025 20:34 #323705 by rodw
Replied by rodw on topic LinuxCNC 2.9.4 Released
The devs are aware of this. There are some Wayland settings to work around it.
The following user(s) said Thank You: unknown
11 Mar 2025 23:28 #323713 by unknown
If it is just "settings" I just hope they're better than the compatibility layer that the rpios uses.
16 Apr 2025 04:18 #326426 by lrak
Replied by lrak on topic LinuxCNC 2.9.4 Released
2.9.4 is released - but not in forum.linuxcnc.org/29-forum-announcements?
Looking via Debian - it appears this is only in sid=unstable - so not yet stable or testing - so your install instructions won't work for anyone running anything other than unstable.
That being said, I currently have 2.9.0~pre1+git20230208.f1270d6ed7-1+deb12u1  under bookworm.
And have had some random resets.. Is there a list of what is fixed in 2.9.4 ?
So to install in bookworm you would have to install half of testing as dependencies.
I'm not complaining - like seeing the progress, but hope this might help others that run stable=bookworm.
I put trixie on a laptop for non linuxcnc - runs well, but lots of libs are getting updated at a high pace as the freeze has been approaching .  trixie is supposed to release sometime in the second half of the year - when it is ready.
[color=#000000]The following packages have unmet dependencies: [/color]
linuxcnc-uspace : Depends: python3 (>= 3.13~) but 3.11.2-1+b1 is to be installed
                  Depends: libc6 (>= 2.38) but 2.36-9+deb12u10 is to be installed
                  Depends: libglib2.0-0t64 (>= 2.12.0) but it is not going to be installed
                  Depends: libgtk-3-0t64 (>= 3.11.5) but it is not going to be installed
                  Depends: libgtk2.0-0t64 (>= 2.8.0) but it is not going to be installed
                  Depends: libpython3.13 (>= 3.13.0~rc3) but it is not going to be installed
                  Depends: libstdc++6 (>= 13.1) but 12.2.0-14 is to be installed
                  Depends: libtirpc3t64 (>= 1.0.2) but it is not going to be installed
                  Depends: libgtksourceview-4-dev but it is not going to be installed
[color=#ff5454]E: [/color][color=#000000]Unable to correct problems, you have held broken packages.[/color]
Hope this is helpful.
  • rodw
  • Platinum Member
  • Platinum Member
19 Apr 2025 08:25 #326671 by rodw
the ISO on the downloads page includes 2.9.4. Trixie/SID is a work in progress. Its not trivial to comply with the Debian build environment and a whole host of  QA requirements imposed by SID. The devs do try...
The following user(s) said Thank You: mjoconr
22 May 2025 03:36 #328891 by mjoconr
Replied by mjoconr on topic LinuxCNC 2.9.4 Released
There is an issue with the ISO for Intel hardware, the package "raspi-firmware" is installed, suggest everyone remove this before running dist-upgrade.
22 May 2025 14:10 #328916 by unknown
That's a well known issue, has been around for years and has been discussed quite a few times.
I'd be careful running dist-upgrade as it can mess kernels up.
If you want to upgrade packages a simple apt upgrade will suffice.
To be honest all I run on my desktops, laptops and servers is apt upgrade.
But if dist-upgrade works for you that's great.
  • rodw
  • Platinum Member
  • Platinum Member
24 May 2025 09:41 #329032 by rodw
Blame Debian.
We suppress it but if you do an upgrade it comes back. A known bug in Debian 12.1 initial release of bookworm, fixed in 12.2 but not in the Debian builder. Very poor form I think.
Time to create page: 0.107 seconds
