- Thank you received: 323
Linuxcnc & the Raspberry Pi (4 & 5) Official Images Only!!!
- unknown
1 year 7 months ago - 1 year 7 months ago #323829
by unknown
Replied by unknown on topic Linuxcnc & the Raspberry Pi (4 & 5) Official Images Only!!!
Ok the description is a little vague.
I don't think a clean install will "fix it". I don't think an update would have anything affect as the kernel,kernel modules and firmwares should not be touched during an update. In all honesty unless you are wanting to update Linuxcnc, there shouldn't be a need to do an update, most updates are just minor fixes that really don't affect the way Linuxcnc operates. The biggest "security threat" to cnc machine is someone getting physical access, and it would be the machine it self I would be the most worried about, blood gets everywhere, it's hard to clean and the injured party may want to blame you. I only will have wifi on when transferring files to the cnc machine, other than that I disconnect wifi.
I think you maybe experiencing an issue similar to what is discussed in this thread. Which it would is not Linuxcnc related, it's the ethernet port going to sleep/shutting down, tho it should be tx\rx ing packets more or less continuously. Yes I know it's a direct connection from the Pi to the Mesa card and the thread mentions switches a few times.
forums.raspberrypi.com/viewtopic.php?t=305820
It seems to be somewhat random to which boards are affected but I haven't noticed this on my RPi400.
Tho it might be an idea to check the power supply for the Pi & the mesa card. But if ti was the mesa card "dropping out" you would get notifications.
Last edit: 1 year 7 months ago by unknown.
- unknown
1 year 7 months ago #323891
by unknown
Dude please don't change the subject, it makes things hard. I check this thread regularly.
- elovalvo
- Thank you received: 127
1 year 7 months ago #323894
by elovalvo
I think it is useful to change the title from
"Linuxcnc & the Rpasberry Pi"
to that
"Linuxcnc & the Raspberry Pi"
Replied by elovalvo on topic Linuxcnc & the Raspberry Pi (4 & 5) Official Images Only!!!
to that
The following user(s) said Thank You: unknown
- Thank you received: 7491
1 year 7 months ago #323921
Replied by tommylight on topic Linuxcnc & the Raspberry Pi (4 & 5) Official Images Only!!!
Fixed title.
- U2fletch
1 year 7 months ago #323983
by U2fletch
Replied by U2fletch on topic Linuxcnc & the Raspberry Pi (4 & 5) Official Images Only!!!
Sorry, did not think it would affect the whole thread.
- U2fletch
1 year 7 months ago #323984
by U2fletch
I have a second Pi 400 on my Ham Radio station, so I switched the two keyboards and fired up LinuxCNC on the "new" board. I let it sit for awhile trying to duplicate what happens. Basically the display becomes unresponsive to anything. The cursor moves around, but I cannot select between pages on GMOCCAPY. However I can still jog the machine around using my pendant, so It is still communicating with the Mesa 7i96 board. Also I cannot ctrl-Esc the Pi to access the task switcher, so something is locking up.
Time to create page: 0.325 seconds
