Linuxcnc & the Raspberry Pi (4 & 5) Official Images Only!!!
1 year 8 months ago #321776 by unknown
If you are using the Linuxcnc 2.9.4 images, and as you claim have any rdp or vnc packages installed it means the images themselves have been compromised. If this is the case I would make a report either on the mailing list or github pages. Links to these can be found at the Linuxcnc homepage.
The copy of the image that I am running on my RPi5 does not have any of the packages pre installed. The images I am using are the ones that I built and submitted to be put on the downloads page.
This is a very serious situation, so I want you think about whether you are using the Linuxcnc images that have been downloaded from the Linuxcnc downloads page and carefully rethink your statement that you did not install these packages yourself.
As I said this is a very serious matter and must be dealt with accordingly.
1 year 8 months ago #321819 by haasme
Sorry, you are right, the original image is clean. :( my mistake!
1 year 8 months ago #321824 by unknown
I don't know why you insisted on saying that it was so, when I clearly told you I created the images and did not have those software packages installed.
Sometimes I don't know why I even fucking bother.
1 year 8 months ago #321830 by haasme
I was after 12 hours of milling parts in the shop, and another 5 hours of trying to set up linuxcnc, so don't be too angry in your judgment.
I also solved the problem as follows:
sudo nano /etc/X11/etc/X11/xrdp/xorg.conf
search for OPTION "DRMDevice" line
and replace with
Option "DRMDevice" ""
save, reboot and all work fine after!
1 year 8 months ago #321885 by unknown
You commits caused somewhat of an issue. Do you think I sat on my hands and did SFA ?
I don't care about your workflow, it's not my issue. My issue was ensuring the integrity of the images.
I don't care about you trying to setup a remote desktop, that was something you decided to do. That software was outside the scope of the software needed to run a cnc machine. I don't know why people ignore using ssh.
The following user(s) said Thank You: behai
1 year 8 months ago #321965 by behai
When I try to log in with rdp from windows 11, it accepts user and pass, but after the image displays something pixelated as if there were 100 miniature desktop . Has anyone else experienced this? (rpi 4 4gb ). Everything else works ok so far..
Hi haasme,
I have tried this dozen times or so, most of the times I had the results as yours. There were times when it worked, I don't know why. I have the desktop, and it responded quite well as well. BUT WHEN I ran glxgears, its own windows with the three gears were pixelated as well. I have since given up on this remote desktop connection. I plan to have another desk and another monitor :) Or perhaps a HDMI switcher (if there is such a thing.)
Best regards,
...behai.
Time to create page: 0.707 seconds
