Linuxcnc & the Raspberry Pi (4 & 5) Official Images Only!!!
1 year 8 months ago #320558 by unknown
As of Feb 4th 2025 the the 6.12.xx series kernel is not supported by Ethercat, so installation will fail. Those wanting Ethercat are encouraged to use the previous version. This is one of the pitfalls of creating images, if a older kernel is used people get upset, if a newer kernel is used people get upset. Eevn if we had of used the Rpi kernel that is "current", 6.6.x series, Ethercat would have the same issue.
Rodw is on to it and has raised the issue on the github repo.
www.linuxcnc.org/iso/rpi-4-debian-bookwo...23-11-17-1731.img.xz
www.linuxcnc.org/iso/rpi-5-debian-bookwo...23-11-17-1520.img.xz
"Does not work" is useless without further information. We do not read minds, I at least don't like playing 1000 questions.
If you have issues writing the image to an SD card, try extracting the image from the downloaded file (don't ask me I don't use windows), as the file is compressed to save space and time downloading, then try writing the image. If that fails check the sha256 sum. Tho if the file is corrupt extracting file will likely fail anyway. So check it first.
The following user(s) said Thank You: behai
1 year 8 months ago #320565 by rodw
Only installation of Ethercat will fail. I have raised an issue with etherlabmaster on their gitlab repo asking if they have a time line for 6.12 support.
I alos pointed out they should get their finger out as Debian Trixie is only a few months away and it is currently running 6.12 :)
The following user(s) said Thank You: behai, bananun
1 year 8 months ago #320567 by unknown
Thanks for clearing that up Rod, it made sense in my mind, which was probably a bad sign. ;)
As a band aid solution I extracted the files from the ethercat-dkms package and ran the update script in the directory for the boardcom stuff, which is a pain as the whole linux sources are need, not just the headers. Anyways some of the patches failed so I gave up on the theory.
1 year 8 months ago - 1 year 5 months ago #320852 by unknown
Regarding GPIO drivers.
For the Rpi5 please use hal_gpio
For the RPi4 hal_pi_gpio or hal_gpio (this looks like the easier option to setup) , should be no need to mess with permissions
linuxcnc.org/docs/devel/html/drivers/hal_gpio.html
linuxcnc.org/docs/devel/html/drivers/hal_pi_gpio.html
Last edit: 1 year 5 months ago by unknown.
1 year 8 months ago #320949 by unknown
Regarding Network Manager
sudo apt install network-manager-gnome
This will install the panel applet and network-manager making managed networking easier to setup.
For a description on networking the debian way.
wiki.debian.org/NetworkManager
1 year 8 months ago #320959 by behai
Thank you for the thread. It is very informative.
In regard to the image linuxcnc.org/iso/rpi-4-debian-bookworm-6...25-01-27-0404.img.xz
and locale, I have been able to verify that locale en US.UTF-8 works for PNCConf.
And after using menu-config to set the locale, I had to restart the machine for it takes effect.
After machine restarted, we should verify the locale. On a terminal window type locale the output should match.
-- I did try to set the locale to en AU.UTF-8 and it did not work.
Thank you and best regards,
...behai.
Time to create page: 0.387 seconds
