Tried every net solution for days to install linuxcnc
- tftmarco0
16 Feb 2025 05:22 #321721
by tftmarco0
Replied by tftmarco0 on topic Tried every net solution for days to install linuxcnc
What image or installer at
"www.debian.org/devel/debian-installer/" should I try? Best fit for my system?
- Thank you received: 4154
16 Feb 2025 05:31 #321722
Replied by rodw on topic Tried every net solution for days to install linuxcnc
The top left one.
Netinst CD image for AMD64
The following user(s) said Thank You: tftmarco0
- tftmarco0
16 Feb 2025 05:35 #321723
by tftmarco0
After Disable secure boot and enable legacy, I got a new error screen with similar message, about not finding the the boot disk. The USB drive is good.
- tftmarco0
16 Feb 2025 05:46 #321724
by tftmarco0
"HDD? Perhaps its a legacy device" I think it is a legacy device with “UEFI: IPv4 Realtek PCIe FE family controller” and “UEFI: IPv6 Realtek PCIe FE family controller” on it somehow. I did reformat it a few times during the partitioning set up. Not sure how "Realtek" keeps coming back unless it is hiding somewhere else or remaining after reformatting.
- tftmarco0
16 Feb 2025 06:00 #321727
by tftmarco0
My USB hard drive is much newer and I know it is good, so I am trying everything I can think of to get linuxcnc on this system. The "boot loader" I believe is in the ISO with everything else it needs to install and I did load it onto both internal and external USB drives. I did try to sign up to the Debian forum, but got the violin questions backwards, now they think I am a robot AI and won't let me join for a month.
- JT
- Thank you received: 615
16 Feb 2025 06:07 #321729
by JT
Replied by JT on topic Tried every net solution for days to install linuxcnc
You might want to try a stable Debian version instead of one that is "Testing".
cdimage.debian.org/debian-cd/current/amd....0-amd64-netinst.iso
JT
JT
- tftmarco0
16 Feb 2025 06:14 #321730
by tftmarco0
I will try the ISO you suggest. The one I did try is "debian-12.9.0-amd64-netinst.iso" and using "rufus-4.6_x86.exe" to make a bootable image for USB thumb drive and USB hard drive.
- unknown
- Thank you received: 323
16 Feb 2025 07:42 #321737
by unknown
Replied by unknown on topic Tried every net solution for days to install linuxcnc
At the end of the installation when it asks you where you want to install the boot loader it should be installed onto the drive that Linux is installed to.
I believe your biggest hurdle is trying to install to a USB drive. The simplest way to install Linux is to a drive that is connected to a SATA or IDE port, or NVME if you have one.
- tftmarco0
16 Feb 2025 07:57 #321740
by tftmarco0
"At the end of the installation when it asks you where you want to install the boot loader" None of the installations that "installed successfully" asked anything about a "boot loader" or where I wanted it to be. I did run across some suggestions that it was left out of the installation repository somehow. I would think it was part of the ISO since it was required for a successful installation.
"The simplest way to install Linux is to a drive that is connected to a SATA or IDE port, or NVME if you have one" The first thing I tried was to install the ISO to the internal hard drive with the suggested partition, formatting, etc. set up for that install.
- unknown
16 Feb 2025 09:06 #321745
by unknown
Well if it didn't, at least for the Debian install something has gone terribly wrong.
Without the installation of a boot loader, or where you want to install grub, the installation won't boot.
But some of this is starting to sound like a troll, based on your previous answers as to where you installed the boot loader. And the fact you never mentioned you tried installing to an internal hard drive to begin with.
Time to create page: 0.271 seconds
