- LinuxCNC
- Installing LinuxCNC
- Script to update 2.9.x ISO to use Linuxcnc Version 2.10 (master branch)
- Thank you received: 4154
23 Mar 2025 07:43 - 03 Apr 2025 03:57 #324652
Script to update 2.9.x ISO to use Linuxcnc Version 2.10 (master branch) was created by rodw
This script installs linuxcnc master branch (2.10) after you have installed the ISO on the downloads page.Hakan has tested and refined this further down this thread so I have updated the script here.
You may want to move to version 2.10 to get the latest QtPlasmac for example as the version in 2.9.4 is no longer maintained.
\Instructions:
1. Download attached script
2. Delete the .txt.extension3. Check permisssions are executible (Right click, Properties and check Permissions tab)
4. Run the script from the folder it is downloaded to: sudo ./update-master.sh
The script deletes and modifies some files in the /etc/apt folder and sub-folders. It does make a copy of the /etc/apt folder into your home folderI tried on one PC and it worked. On another PC it didn't. If it fails, open the file and run each line individually
after the apt upgrade is complete, running linuxcnc should show version 2.10 on startup in the console and the splash screen.
To update down the track
sudo apt update && sudo apt upgrade
\Instructions:
Last edit: 03 Apr 2025 03:57 by rodw. Reason: Updated script. Thanks Hakan!
- Thank you received: 7504
23 Mar 2025 08:32 #324663
Replied by tommylight on topic Script to update 2.9.x ISO to use Linuxcnc Version 2.10 (master branch)
That file contains:1. it does not add the repository, it only adds the key
2. deleting stuff on user PC's is never a good idea, at least add a warning for them to confirm the risk.
#! /bin/bash
mkdir ~/apt
sudo cp -r /etc/apt/*.* ~/apt
sudo wget http://buildbot2.highlab.com/buildbot-archive-key.gpg /etc/apt/trusted.gpg.d
sudo rm -f /etc/apt/preferences.d/99linuxcnc-uspace.pref
sudo rm -f /etc/apt/sources.list.d/linuxcnc-uspace.list
sudo apt update
sudo apt upgrade2. deleting stuff on user PC's is never a good idea, at least add a warning for them to confirm the risk.
23 Mar 2025 17:02 - 02 Apr 2025 15:52 #324701
Replied by rodw on topic Script to update 2.9.x ISO to use Linuxcnc Version 2.10 (master branch)
Oops, revised script attachedThe files I deleted, I created via the Linuxcnc installer I wrote, hence the backup.
Last edit: 02 Apr 2025 15:52 by rodw.
23 Mar 2025 17:27 #324704
Does not work, permission denied, and yes used sudo.
Repositories should be added using
apt-add-repository
echo most probably does not work for system files.
and this is wrong,
echo "deb buildbot2.highlab.com/debian/ bookworm master-uspace 2.9-uspace" >> /etc/apt/sources.list
That is adding master and 2.9 so apt will complain about it.
And the key is not installed properly, it is left in the home folder so it has to be imported manually.
apt-add-repository
and this is wrong,
23 Mar 2025 18:57 - 31 Mar 2025 03:22 #324710
Thats what happens on the way out the door to work
Run these commands one by one
if the echo command does not work then
and add the text in "" manually at the end of the file
cd ~
mkdir ~/apt
echo "deb http://buildbot2.highlab.com/debian/ bookworm master-uspace 2.9-uspace" >> /etc/apt/sources.list
sudo apt update
sudo apt upgradeif the echo command does not work then
sudo geany /etc/apt/sources.listand add the text in "" manually at the end of the file
Last edit: 31 Mar 2025 03:22 by rodw.
23 Mar 2025 19:33 #324711
sudo apt-add-repository "deb http://buildbot2.highlab.com/debian/ bookworm master-uspace 2.9-uspace"
- H-S-W
31 Mar 2025 03:14 #325364
by H-S-W
Replied by H-S-W on topic Script to update 2.9.x ISO to use Linuxcnc Version 2.10 (master branch)
Hi guys!
New user here with limited knowledge. Trying to convert an old mill, have a rpi5 and a 7i97T for the job. Planned to use MesaCT to help me with the start of the config, but there is states the 7i97T needs LinuxCNC 2.10.
I've already installed the "Raspberry Pi 5 OS based on Debian Bookworm " from the website, which i'm now trying to update using this post. No luck so far for me!
seems to fail from;
sudo cp -r /etc/apt/*.* ~/aptsudo wget buildbot2.highlab.com/buildbot-archive-key.gpg /etc/apt/trusted.gpg.d
returns;
cp: cannot copy a directory, '/etc/apt/trusted.gpg.d', into itself, '/etc/apt/trusted.gpg.d/trusted.gpg.d'
cp: cannot stat '/home/cnc/aptsudo': No such file or directory
cp: cannot stat 'wget': No such file or directory
cp: cannot stat 'buildbot2.highlab.com/buildbot-archive-key.gpg': No such file or directory
seems to fail from;
returns;
31 Mar 2025 03:23 #325366
Sorry, the forum broke it.
I edited the post above
31 Mar 2025 03:25 #325367
Ooops, I don't think this will work on the Pi5
- H-S-W
31 Mar 2025 03:56 #325368
by H-S-W
Maybe not.. now it stops at:
cnc@raspberrypi:~$ sudo echo "deb buildbot2.highlab.com/debian/ bookworm master-uspace 2.9-uspace" >> /etc/apt/sources.list
bash: /etc/apt/sources.list: Permission denied
- LinuxCNC
Time to create page: 0.562 seconds
