- LinuxCNC
- Installing LinuxCNC
- Script to update 2.9.x ISO to use Linuxcnc Version 2.10 (master branch)
- Thank you received: 7504
31 Mar 2025 04:11 #325371
Replied by tommylight on topic Script to update 2.9.x ISO to use Linuxcnc Version 2.10 (master branch)
Echo does not work, try this
forum.linuxcnc.org/9-installing-linuxcnc...master-branch#324711
- H-S-W
02 Apr 2025 02:35 #325498
by H-S-W
Replied by H-S-W on topic Script to update 2.9.x ISO to use Linuxcnc Version 2.10 (master branch)
cnc@raspberrypi:~$ sudo apt-add-repository "deb buildbot2.highlab.com/debian/ bookworm master-uspace 2.9-uspace"
sudo: apt-add-repository: command not found
- Thank you received: 4154
02 Apr 2025 03:28 - 02 Apr 2025 03:30 #325499
Replied by rodw on topic Script to update 2.9.x ISO to use Linuxcnc Version 2.10 (master branch)
Try this line but make sure you run the lines containing the rm command first
sudo echo "deb http://buildbot2.highlab.com/debian/ bookworm master-uspace 2.9-uspace" >> /etc/apt/sources.list.d/linuxcnc-uspace.list
Last edit: 02 Apr 2025 03:30 by rodw.
- Hakan
- Thank you received: 481
02 Apr 2025 08:14 #325513
by Hakan
Replied by Hakan on topic Script to update 2.9.x ISO to use Linuxcnc Version 2.10 (master branch)
Won't work, redirect of output is not done by superuser but by the invoking user.
Some solutions here stackoverflow.com/questions/84882/sudo-e...egedfile-doesnt-work
02 Apr 2025 14:47 #325536
I tested this on my chromebook but there the user has root permissions
Something like this should then work as a script.
Ahh thanks, all my scripting has been done in installers as rootWon't work, redirect of output is not done by superuser but by the invoking user.
mkdir ~/apt
sudo cp -r /etc/apt/*.* ~/apt
sudo wget http://buildbot2.highlab.com/buildbot-archive-key.gpg /etc/apt/trusted.gpg.d
sudo rm -f /etc/apt/preferences.d/99linuxcnc-uspace.pref
sudo rm -f /etc/apt/sources.list.d/linuxcnc-uspace.list
sudo tee /etc/apt/sources.list.d/linuxcnc-uspace.list > /dev/null <<EOT
EOT
sudo apt update
sudo apt upgradePlease Log in or Create an account to join the conversation.
- Hakan
02 Apr 2025 15:24 #325540
by Hakan
That worked. Was it supposed to overwrite the content of the linuxcnc-uspace.list?
That's what it did anyway. If you just wanted to add a new line at the end, "tee -a" is the answer.
Considering you did that in the previous commands with echo and >>
02 Apr 2025 15:48 #325543
Cool, the ISO install points that file to the Linuxcnc.org repositories so deleting it let it us overwrite it to use buildbot2
Also we have a preferences file we delete to ensure Debian chose the Linuxcnc version at Linuxcnc.org, not the obsolete one in the Bookworm distribution. I don't think we need that here because version 2.10 is > 2.94 (it worked for you)
If we do, we can edit the saved preferences version from the apt folder in your home folder or get it from the linuxcnc-livebuild (the binary versions are what we use, chroot is just for the builder)
github.com/LinuxCNC/linuxcnc-live-build/...worm/config/archives
Finally, I might add that this install is not best practice for apt. If you look at the Ethercat list.binary file, the key is explicitly referenced in the Deb archive line
- Hakan
03 Apr 2025 02:13 - 03 Apr 2025 02:23 #325590
by Hakan
I actually only tested that "tee" line.
But now I have tested the script and it fails on the "apt update" line.
Found it, there should be a "-P" in the wget command
The output of "apt list --upgradable" shows a number of 2.10 packages such as
linuxcnc-uspace/stable 1:2.10.0~pre0.4165.g55fb1a0267 amd64
Error:9 http://buildbot2.highlab.com/debian bookworm InRelease
The following signatures couldn't be verified because the public key is not available: NO_PUBKEY EF1B07FEE0EE663E
W: GPG-fel: http://buildbot2.highlab.com/debian bookworm InRelease: the following signatures couldn't be verified because the public key is not available: NO_PUBKEY EF1B07FEE0EE663E
E: The repository 'http://buildbot2.highlab.com/debian bookworm InRelease' is not signed.
N: Updating from such a repository can't be done securely, and is therefore disabled by default.
N: See apt-secure(8) manpage for repository creation and user configuration details.Found it, there should be a "-P" in the wget command
sudo wget http://buildbot2.highlab.com/buildbot-archive-key.gpg -P /etc/apt/trusted.gpg.dThe output of "apt list --upgradable" shows a number of 2.10 packages such as
Last edit: 03 Apr 2025 02:23 by Hakan.
03 Apr 2025 02:31 - 03 Apr 2025 02:54 #325592
These keys are a right pain in the butt, I have been it all before.
Try this which links the key on the Deb line.
You could just use sudo Geany to edit the file, but we know the script works you may need to delete the backup folder ~/apt
#! /bin/bash
mkdir ~/apt
deb [arch=amd64, signed-by=/etc/apt/trusted.gpg.d/buildbot-archive-key.gpg] http://buildbot2.highlab.com/debian/ bookworm master-uspace 2.9-uspace
EOT
sudo apt update
sudo apt upgrade
Last edit: 03 Apr 2025 02:54 by rodw.
- Hakan
03 Apr 2025 02:52 - 03 Apr 2025 02:52 #325593
by Hakan
I guess you missed the edit I did on that message. There should be a "-P" on the wget line to put the downloaded key in the right place.
Last edit: 03 Apr 2025 02:52 by Hakan.
- LinuxCNC
Time to create page: 0.226 seconds
