Not able to get outputs on GPIO of Raspberry5
- AndyCNC
25 May 2025 15:49 #329112
by AndyCNC
Not able to get outputs on GPIO of Raspberry5 was created by AndyCNC
I'm a bit desperate. I want to replace my very old pc based linuxcnc with the actual version running on a raspberry pi 5.
I've been trying to get signals to the pin header for a day now.
First of all: Is there a tutorial for raspberry configuration? I found nothing except the general docu and then went from one error message to another.
What I did is:
1. Started Stepconf wizard
2. Replaced parallel port Pins with hal_gpioxxx, see attached hal file
When I start this Setup following error occurs:
This was my try to set the PINs:
Would be nice if onyone could show my where I'm wrong.
Andy
What I did is:
halcmd: loadrt hal_gpio inputs=PIN3,PIN5,PIN7 outputs=PIN5,PIN6,PIN9,PIN10,PIN11,PIN17,PIN22,PIN27
Note: Using POSIX realtime
The GPIO line PIN3 can not be found
hal_gpio: rtapi_app_main: Operation not permitted (-1)
<stdin>:12: waitpid failed /usr/bin/rtapi_app hal_gpio
<stdin>:12: /usr/bin/rtapi_app exited without becoming ready
<stdin>:12: insmod for hal_gpio failed, returned -1
halcmd: Note: Using POSIX realtime
Andy
25 May 2025 15:54 #329113
Replied by andypugh on topic Not able to get outputs on GPIO of Raspberry5
Have you run the "gpioinfo" command? That will list the available pins. If it doesn't work that may mean that you don't have gpiod installed.
Is your user account a member of the "dialout" group?
forums.raspberrypi.com/viewtopic.php?t=225274
- AndyCNC
25 May 2025 16:56 #329124
by AndyCNC
Replied by AndyCNC on topic Not able to get outputs on GPIO of Raspberry5
Thanks for your fast reply.
That's the output of "gpioinfo", looks ok for me:
And group "dialout" seems to fit also:
[color=#55ff55][b]cnc@fraese[/b][/color]:[color=#5555ff][b]~[/b][/color]$ gpioinfo
gpiochip0 - 54 lines:
line 0: "ID_SDA" unused input active-high
line 1: "ID_SCL" unused input active-high
line 2: "GPIO2" unused input active-high
line 3: "GPIO3" unused input active-high
line 4: "GPIO4" unused input active-high
line 5: "GPIO5" unused input active-high
line 6: "GPIO6" unused input active-high
line 7: "GPIO7" "spi0 CS1" output active-low [used]
line 8: "GPIO8" "spi0 CS0" output active-low [used]
line 9: "GPIO9" unused input active-high
line 10: "GPIO10" unused input active-high
line 11: "GPIO11" unused input active-high
line 12: "GPIO12" unused input active-high
line 13: "GPIO13" unused input active-high
line 14: "GPIO14" unused input active-high
line 15: "GPIO15" unused input active-high
line 16: "GPIO16" unused input active-high
line 17: "GPIO17" unused input active-high
line 18: "GPIO18" unused input active-high
line 19: "GPIO19" unused input active-high
line 20: "GPIO20" unused input active-high
line 21: "GPIO21" unused input active-high
line 22: "GPIO22" unused input active-high
line 23: "GPIO23" unused input active-high
line 24: "GPIO24" unused input active-high
line 25: "GPIO25" unused input active-high
line 26: "GPIO26" unused input active-high
line 27: "GPIO27" unused input active-high
line 28: "PCIE_RP1_WAKE" unused input active-high
line 29: "FAN_TACH" unused input active-high
line 30: "HOST_SDA" unused input active-high
line 31: "HOST_SCL" unused input active-high
line 32: "ETH_RST_N" "phy-reset" output active-low [used]
line 33: "-" unused input active-high
line 34: "CD0_IO0_MICCLK" "cam0_reg" output active-high [used]
line 35: "CD0_IO0_MICDAT0" unused input active-high
line 36: "RP1_PCIE_CLKREQ_N" unused input active-high
line 37: "-" unused input active-high
line 38: "CD0_SDA" unused input active-high
line 39: "CD0_SCL" unused input active-high
line 40: "CD1_SDA" unused input active-high
line 41: "CD1_SCL" unused input active-high
line 42: "USB_VBUS_EN" unused output active-high
line 43: "USB_OC_N" unused input active-high
line 44: "RP1_STAT_LED" "PWR" output active-low [used]
line 45: "FAN_PWM" unused output active-high
line 46: "CD1_IO0_MICCLK" "cam1_reg" output active-high [used]
line 47: "2712_WAKE" unused input active-high
line 48: "CD1_IO1_MICDAT1" unused input active-high
line 49: "EN_MAX_USB_CUR" unused output active-high
line 50: "-" unused input active-high
line 51: "-" unused input active-high
line 52: "-" unused input active-high
line 53: "-" unused input active-high
gpiochip10 - 32 lines:
line 0: "-" unused input active-high
line 1: "2712_BOOT_CS_N" "spi10 CS0" output active-low [used]
line 2: "2712_BOOT_MISO" unused input active-high
line 3: "2712_BOOT_MOSI" unused input active-high
line 4: "2712_BOOT_SCLK" unused input active-high
line 5: "-" unused input active-high
line 6: "-" unused input active-high
line 7: "-" unused input active-high
line 8: "-" unused input active-high
line 9: "-" unused input active-high
line 10: "-" unused input active-high
line 11: "-" unused input active-high
line 12: "-" unused input active-high
line 13: "-" unused input active-high
line 14: "PCIE_SDA" unused input active-high
line 15: "PCIE_SCL" unused input active-high
line 16: "-" unused input active-high
line 17: "-" unused input active-high
line 18: "-" unused input active-high
line 19: "-" unused input active-high
line 20: "PWR_GPIO" "pwr_button" input active-low [used]
line 21: "2712_G21_FS" unused input active-high
line 22: "-" unused input active-high
line 23: "-" unused input active-high
line 24: "BT_RTS" unused input active-high
line 25: "BT_CTS" unused input active-high
line 26: "BT_TXD" unused input active-high
line 27: "BT_RXD" unused input active-high
line 28: "WL_ON" "wl_on_reg" output active-high [used]
line 29: "BT_ON" "shutdown" output active-high [used]
line 30: "WIFI_SDIO_CLK" unused input active-high
line 31: "WIFI_SDIO_CMD" unused input active-high
gpiochip11 - 15 lines:
line 0: "RP1_SDA" unused input active-high
line 1: "RP1_SCL" unused input active-high
line 2: "RP1_RUN" "RP1 RUN pin" output active-high [used]
line 3: "SD_IOVDD_SEL" "vdd-sd-io" output active-high [used]
line 4: "SD_PWR_ON" "sd_vcc_reg" output active-high [used]
line 5: "SD_CDET_N" "cd" input active-low [used]
line 6: "SD_FLG_N" unused input active-high
line 8: "2712_WAKE" unused input active-high
line 9: "2712_STAT_LED" "ACT" output active-low [used]
line 12: "PMIC_INT" unused input active-high
line 13: "UART_TX_FS" unused input active-high
line 14: "UART_RX_FS" unused input active-high
gpiochip12 - 6 lines:
line 0: "HDMI0_SCL" unused input active-high
line 1: "HDMI0_SDA" unused input active-high
line 2: "HDMI1_SCL" unused input active-high
line 3: "HDMI1_SDA" unused input active-high
line 4: "PMIC_SCL" unused input active-high
line 5: "PMIC_SDA" unused input active-high
gpiochip13 - 4 lines:
line 0: "WIFI_SDIO_D0" unused input active-high
line 1: "WIFI_SDIO_D1" unused input active-high
line 2: "WIFI_SDIO_D2" unused input active-high
line 3: "WIFI_SDIO_D3" unused input active-high And group "dialout" seems to fit also:
[color=#55ff55][b]cnc@fraese[/b][/color]:[color=#5555ff][b]~[/b][/color]$ groups cnc
cnc : cnc tty disk dialout sudo audio video plugdev users input render netdev i2c bluetooth gpio spi
[color=#55ff55][b]cnc@fraese[/b][/color]:[color=#5555ff][b]~[/b][/color]$ Please Log in or Create an account to join the conversation.
- unknown
- Thank you received: 323
25 May 2025 23:08 #329134
by unknown
Replied by unknown on topic Not able to get outputs on GPIO of Raspberry5
forum.linuxcnc.org/38-general-linuxcnc-q...official-images-only
Index to major thread, there's a section regarding your query with an example for a simple 3 axis machine that works.
- unknown
26 May 2025 01:02 #329139
by unknown
Link to manpage
linuxcnc.org/docs/devel/html/drivers/hal_gpio.html
First hint is here:
The GPIO line PIN3 can not be found.
PIN3 isn't a name of a pin, pins are named as per man page.
First hint is here:
- AndyCNC
26 May 2025 06:47 #329145
by AndyCNC
Thanks. When I use the naming in the linked config instead of the naming from docu it works!
I can see dir and step signals now on the correct pins.
One last problem before I can test with the machine. I use an enable signal for the stepper driver. I see it on the pin, but inverted. Is there a possibility to invert output pins at raspberry pi 5 or should I better do it in hardware?
Time to create page: 0.070 seconds
