Graphical glitches with Raspberry Pi 400 + LinuxCNC 2.9.4 (arm64)
- phino
- Online
This was tested with Firefox ESR, but Chromium was also installed, and for example, the settings page for Chromium never displays properly. It would appear the underlying text and buttons/links are present but not visible, except by sometimes mousing over them.
The problem appears to be only in browsers, not other applications. Youtube in either browser is also unusable, with graphical glitches on the player controls (YT buttons like play/pause/settings are either invisible or look corrupt).
Similarly, when opening PDF documents in browsers, the control buttons along the top of the document for Zoom/Download/Save etc are often invisible, but still present if moused over.
Also, Youtube video playback is extremely laggy, and that is including after removing the isolcpu=2,3 option. The goal on the Pi is just to familiarize with LinuxCNC and set up configs, not to run machines on it, so I'm not too concerned about the latency penalty in this case..
Has anyone else experienced this problem?
- unknown
- Thank you received: 323
When I build the image I put it through the basic tasks, and if I had of seen this issue arise I wouldn't have released the image, I would have deemed it defective and not fit for purpose.
Now we are going to require some more info, what monitor (brand model) screen resolution and such. And just to be sure I would like to know if this is a clean install without any extras added. If you can remember when was the last time you did an update.
And yes the RPi400 should give reasonable playback on youtube and reading pdfs shouldn't pose an issue. When I get the time I'll recheck things but as I said before I haven't seen this issue arise during testing and so far in the 6 months it has been out in the wild no one else has mentioned this.
One thing I would suggest is look at this thread, forum.linuxcnc.org/38-general-linuxcnc-q...l-images-only#325007 and take note of the video issue link & zswap link.
- Thank you received: 7478
It sure points that way...
- phino
- Online
The SD cards used are 64GB Kingston Canvas Select Plus. Nothing fancy, but I doubt it is the issue, since I've used multiple, and other images (default RPi OS, Ubuntu 24.04) don't have the same issue.
For reference, here are some screenshots of the glitches in chromium. Btw, I had to install xfce4-screenshooter to be able to take screenshots, as it is not installed by default in the LinuxCNC rpi image.
The first screenshot shows a horizontal section of the web page with corrupted graphics. The second is chromium's setting page which never displays correctly. The third is a pdf document opened in chromium, with the controls (download, zoom, etc) at the top not showing. The fourth shows the graphical glitches in the Youtube player controls (buttons for play, pause, settings, etc).
They work in Firefox (very slow though, which is why I installed chromium) so perhaps this is not an issue specifically with LinuxCNC's image, though I can't tell. I don't have these issues with chromium on the other RPi OS images, but I have not tried debian 12 directly. I imagine that also precludes hardware issues. The monitor is a 22" Dell at 1680x1050, though I doubt that is too relevant.
Aside from isolcpu, were there other optimizations made which may impact graphical or general performance?
- unknown
To tell the truth when I test the images I use an old 19" 4:3 monitor. Another thing to be aware of is that the images aren't meant to be for a daily driver, the sole purpose is to run Linuxcnc which is what is concentrated on. So yes there will be packages left out that are part of a standard Desktop install.
The kernel was built using the official RPi sources, with the only mod being enabling the RT section in the kernel config. So there is really nothing fancy in that area.
It very well be an issue related to resolution, in config.txt you should be able to adjust the memory allocated to the graphics system, something you'll have to look at the config.txt documentation, 2 things to be aware of, there is no raspi-config utility so the config.txt will need to be hand edited and the location of it is different to the Raspberry OS, the main thread for the images has this info.
If you just want to explore what Linuxcnc has to offer without running a machine or connecting to any hardware there is also the option of running the amd64 version as a live session on a PC or installing in a virtual machine such as VirtualBox. RT capabilities will be non existent but it will run the simulations fine.
Another option would be to install RaspiOS and build Linuxcnc from source, a real time kernel would not be required in your case and use at ad a Run In Place install. How to do this can be found in the docs.
- phino
- Online
Graphics Feature Status
Canvas: Hardware accelerated
Direct Rendering Display Compositor: Disabled
Compositing: Hardware accelerated
Multiple Raster Threads: Enabled
OpenGL: Enabled
Rasterization: Hardware accelerated on all pages
Raw Draw: Disabled
Skia Graphite: Disabled
TreesInViz: Disabled
Video Decode: Software only. Hardware acceleration disabled
Video Encode: Software only. Hardware acceleration disabled
Vulkan: Disabled
WebGL: Hardware accelerated
WebGL2: Hardware accelerated
WebGPU: Disabled
WebNN: Disabled
Full report attached below.Problems Detected
WebGPU has been disabled via blocklist or the command line.
Disabled Features: webgpu
Accelerated video encode has been disabled, either via blocklist, about:flags or the command line.
Disabled Features: video_encode
Accelerated video decode has been disabled, either via blocklist, about:flags or the command line.
Disabled Features: video_decode
Disable partial swaps on Mesa drivers (detected with GL_VERSION): 339493
Applied Workarounds: disable_post_sub_buffers_for_onscreen_surfaces
Disable KHR_blend_equation_advanced until cc shaders are updated: 661715
Applied Workarounds: disable(GL_KHR_blend_equation_advanced), disable(GL_KHR_blend_equation_advanced_coherent)
Expose WebGL's disjoint_timer_query extensions on platforms with site isolation: 808744, 870491
Applied Workarounds: enable_webgl_timer_query_extensions
Some drivers can't recover after OUT_OF_MEM and context lost: 893177
Applied Workarounds: exit_on_context_lost
Avoid waiting on a egl fence before swapping buffers and rely on implicit sync on Broadcom GPUs: 938286
Applied Workarounds: rely_on_implicit_sync_for_swap_buffers
Disable GL_MESA_framebuffer_flip_y for desktop GL: 964010
Applied Workarounds: disable(GL_MESA_framebuffer_flip_y)
I don't think the issue is hardware or resolution, since it is just this image that has these problems.
- unknown
To be quite blunt this is a low priority issue, as the primary function of the image is to run a CNC machine. Which by all accounts it has done quite well, the only show stopper was the zswap issue for one user, but this was resolved.
I may sound like an ass and appear to be unhelpful, but as I said before it's a low priority issue and so far has not, no reports, has affected the operation of a Linuxcnc session.
- phino
- Online
Is there a guideline on how much memory to allocate to the GPU? This is a 4GB Pi 400. One idea I have is to compare the config.txt with that of other images that work well.
The other thought is regarding codecs or configuration that may be missing as suggested by the attached report from the chrome://gpu
- unknown
You will have to read the main thread to find the location of this file as it is not in the same location as the raspberry pi images.
Honestly for your case use I would ditch the Linuxcnc image, install Linuxcnc via apt to a RaspiOS, there is information on the forum regarding this, or as I mentioned earlier build from source, you don't require an RT kernel to build from source.
The zswap fix is to actually have swap a compressed swap in memory. It is not just to "fix an error log message", which you don't seem to understand.
If you aren't going to bother to try I can't be fucked to give you help on what is really a non issue for an image created to run a CNC machine which is something you admitted you are not intending to do. And in that case you have been given suggestions to overcome what is a very minor issue.
Regarding the zswap it seems you didn't see or ignored the issue it caused for a user when the system was left idle. I'll repeat this one more time, it is not a fix for an error log message, the error log message pointed to an actual issue and the fix was to fix the actual issue.
So far I have offered some suggestions, yet you have not bothered to attempt any. Maybe this image is not suitable for your intended use and another solution maybe a better path to take.
Good luck in your endeavours but I have exhausted my patience and will to help
