Debian Trixie upgrade/install to 2.9.4
1 year 2 months ago #333796 by rodw
Last time it expired, they fixed it when I asked them to so nothing to worry about.
The following user(s) said Thank You: jjdege
1 year 1 month ago - 1 year 1 month ago #334447 by jaapiyo
So I've been trying to get this to work and I keep getting some error with dpkg.
I'm running a clean install from the latest iso from linuxcnc.org. Upgrading to trixie according to the instructions by rodw. My hardware is a NUC 14 with an Intel N150 processor.
After this operation, 409 MB disk space will be freed.Do you want to continue? [Y/n] y (Reading database ... 179287 files and directories currently installed.) Removing linux-image-6.1.0-30-rt-amd64 (6.1.124-1) ... /etc/kernel/postrm.d/initramfs-tools: update-initramfs: Deleting /boot/initrd.img-6.1.0-30-rt-amd64 /etc/kernel/postrm.d/z50-raspi-firmware: raspi-firmware: missing /boot/firmware, did you forget to mount it? run-parts: /etc/kernel/postrm.d/z50-raspi-firmware exited with return code 1 dpkg: error processing package linux-image-6.1.0-30-rt-amd64 (--remove): installed linux-image-6.1.0-30-rt-amd64 package post-removal script subprocess returned error exit status 1 dpkg: too many errors, stopping Errors were encountered while processing: linux-image-6.1.0-30-rt-amd64 Processing was halted because there were too many errors.
What's this raspi-firmware doing here? Is this causing my issue or can it be ignored? It's quite late here, so I'm done for today. I hope someone can point me in the right direction.
Last edit: 1 year 1 month ago by jaapiyo.
1 year 1 month ago #334453 by unknown
Oh this old gem, the solution is to remove or purge the offending raspberry pi package. Its been mentioned many many times throughout the forum, the exact commands can be found with a quick search.
The following user(s) said Thank You: COFHAL
9 months 3 days ago #342114 by COFHAL
Excuse my ignorance, but how do I create an image of the contents of one hard drive to install it on another? This is to avoid having to reinstall the additional applications I use with LCN.
9 months 3 days ago #342119 by unknown
Google "linux clone hdd"
And choose your poison, the subject is a bit expansive, and it's not something I'd like to describe to a newbie. There are many many ways to do this.
You can also use debian's preseed config to install extra apps.
Once again google "debian preseed" and you will have a clean install without any fluff.
9 months 3 days ago - 9 months 3 days ago #342126 by COFHAL
Thank you for your response, and also for your subtle sarcasm in calling me ignorant every time I comment or ask for help in the threads you also participate in. But I think it's better to be considered ignorant than to learn nothing, even if you're treated like garbage. What I'm trying to figure out is how to create an .img file of my hard drive's contents without having to reinstall applications that aren't included in the .img file, like the one you created for the Raspberry Pi 4 with Debian 13, which I've already installed on four Pi 4s. After installation, I add other applications and compile some components that aren't included in the official LCN version, and doing all that every time I install the image you created wastes a lot of my time.
Last edit: 9 months 3 days ago by COFHAL.
