Strugling with installation
1 year 2 days ago - 1 year 1 day ago #337522 by john.obrien
@unknown reflecting on this, I executed
apt get update
apt get upgrade
and encountered the error. I did not (as you indicated) execute
apt get remove
on a fresh installation right after login. So, that is maybe the difference. You are likely entirely correct that executing apt get remove right after login on first install will fix the issue. That said, I suspect most folks are going to come across the error only after trying to do an apt get upgrade, so my note is aimed at those folks, who when searching might come across this discussion.
Last edit: 1 year 1 day ago by john.obrien. Reason: further reflection
Time to create page: 0.101 seconds
