Strugling with installation
1 year 3 weeks ago #336240 by tommylight
Did you do this
sudo apt purge raspi-firmware
After you do
sudo apt update
then you can upgrade if you want to
[sudo apt upgrade[/code]
Then you can install whatever you want as usual.
1 year 3 weeks ago #336245 by Digger011
Tommy, thanks for the instructions.
milos@cnc:~$ apt list --upgradable
Listing... Done
libtiff-dev/oldstable-security 4.5.0-6+deb12u3 amd64 [upgradable from: 4.5.0-6+deb12u2]
libtiff6/oldstable-security 4.5.0-6+deb12u3 amd64 [upgradable from: 4.5.0-6+deb12u2]
libtiffxx6/oldstable-security 4.5.0-6+deb12u3 amd64 [upgradable from: 4.5.0-6+deb12u2]
milos@cnc:~$ sudo apt upgrade libtiff-dev/oldstable-security 4.5.0-6+deb12u3 amd64
Reading package lists... Done
Building dependency tree... Done
Reading state information... Done
E: Unable to locate package 4.5.0-6+deb12u3
E: Couldn't find any package by glob '4.5.0-6+deb12u3'
E: Unable to locate package amd64
Calculating upgrade... Done
The following packages will be upgraded:
  libtiff-dev libtiff6 libtiffxx6
3 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
3 not fully installed or removed.
Need to get 916 kB of archives.
After this operation, 0 B of additional disk space will be used.
Do you want to continue? [Y/n] y
Get:1 security.debian.org/debian-security bookworm-security/main amd64 libtiff-dev amd64 4.5.0-6+deb12u3 [456 kB]
Get:2 security.debian.org/debian-security bookworm-security/main amd64 libtiff6 amd64 4.5.0-6+deb12u3 [316 kB]
Get:3 security.debian.org/debian-security bookworm-security/main amd64 libtiffxx6 amd64 4.5.0-6+deb12u3 [144 kB]
Fetched 916 kB in 0s (2,671 kB/s)
(Reading database ... 180636 files and directories currently installed.)
Preparing to unpack .../libtiff-dev_4.5.0-6+deb12u3_amd64.deb ...
Unpacking libtiff-dev:amd64 (4.5.0-6+deb12u3) over (4.5.0-6+deb12u2) ...
Preparing to unpack .../libtiff6_4.5.0-6+deb12u3_amd64.deb ...
Unpacking libtiff6:amd64 (4.5.0-6+deb12u3) over (4.5.0-6+deb12u2) ...
Preparing to unpack .../libtiffxx6_4.5.0-6+deb12u3_amd64.deb ...
Unpacking libtiffxx6:amd64 (4.5.0-6+deb12u3) over (4.5.0-6+deb12u2) ...
Setting up initramfs-tools (0.142+deb12u3) ...
update-initramfs: deferring update (trigger activated)
Setting up libtiff6:amd64 (4.5.0-6+deb12u3) ...
Setting up libtiffxx6:amd64 (4.5.0-6+deb12u3) ...
Setting up linux-image-6.1.0-40-rt-amd64 (6.1.153-1) ...
/etc/kernel/postinst.d/dkms:
dkms: running auto installation service for kernel 6.1.0-40-rt-amd64.
dkms: autoinstall for kernel: 6.1.0-40-rt-amd64.
/etc/kernel/postinst.d/initramfs-tools:
update-initramfs: Generating /boot/initrd.img-6.1.0-40-rt-amd64
raspi-firmware: missing /boot/firmware, did you forget to mount it?
run-parts: /etc/initramfs/post-update.d//z50-raspi-firmware exited with return code 1
run-parts: /etc/kernel/postinst.d/initramfs-tools exited with return code 1
dpkg: error processing package linux-image-6.1.0-40-rt-amd64 (--configure):
 installed linux-image-6.1.0-40-rt-amd64 package post-installation script subprocess returned error exit status 1
Setting up libtiff-dev:amd64 (4.5.0-6+deb12u3) ...
dpkg: dependency problems prevent configuration of linux-image-rt-amd64:
 linux-image-rt-amd64 depends on linux-image-6.1.0-40-rt-amd64 (= 6.1.153-1); however:
  Package linux-image-6.1.0-40-rt-amd64 is not configured yet.
dpkg: error processing package linux-image-rt-amd64 (--configure):
 dependency problems - leaving unconfigured
Processing triggers for man-db (2.11.2-2) ...
Processing triggers for libc-bin (2.36-9+deb12u13) ...
Processing triggers for initramfs-tools (0.142+deb12u3) ...
dpkg: error processing package initramfs-tools (--configure):
 installed initramfs-tools package post-installation script subprocess returned error exit status 1
Errors were encountered while processing:
 initramfs-tools
E: Sub-process /usr/bin/dpkg returned an error code (1)
Wonering what am I doing wrong.
M
1 year 3 weeks ago #336246 by tommylight
Try
sudo apt purge *raspi*
then sudo apt update
Sorry, i copied and pasted that line from the post i linked and now i noticed that line will not work as was written there, dang, now i have to find all the posts about it and fix them.
Not my mess, luckily, but i hate dealing with it as it's been dragging for over a year now, all because someone did not clean the build environment before building the ISO.
1 year 3 weeks ago #336250 by Digger011
No problem Tommy, I should be sorry to bug you for all of this.
Here is what is going on:
milos@cnc:~$ sudo apt purge *raspi*
[sudo] password for milos:
Note, selecting 'linux-firmware-raspi3' for glob '*raspi*'
Note, selecting 'raspi-firmware' for glob '*raspi*'
Note, selecting 'raspi3-firmware' for glob '*raspi*'
Package 'linux-firmware-raspi3' is not installed, so not removed
Package 'raspi3-firmware' is not installed, so not removed
The following packages will be REMOVED:
  raspi-firmware*
0 upgraded, 0 newly installed, 1 to remove and 0 not upgraded.
milos@cnc:~$ sudo apt update
Hit:1 deb.debian.org/debian bookworm InRelease
Hit:2 deb.debian.org/debian bookworm-updates InRelease
Hit:3 security.debian.org/debian-security bookworm-security InRelease
Hit:4 www.linuxcnc.org bookworm InRelease
Hit:5 repository.qtpyvcp.com/apt develop InRelease
Hit:6 download.opensuse.org/repositories/science:/EtherLab/Debian_12 ./ InRelease
All packages are up to date.
Does it mean that everything is ok now? There was an error, but after update it looks ok.
M
1 year 3 weeks ago #336251 by tommylight
Nope, not entirely, but something did, so give this a go
sudo rm /etc/{initramfs/post-update.d/,kernel/{postinst.d/,postrm.d/}}z50-raspi-firmware
and post the result.
1 year 3 weeks ago #336252 by Digger011
Here they are:
milos@cnc:~$ sudo rm /etc/{initramfs/post-update.d/,kernel/{postinst.d/,postrm.d/}}z50-raspi-firmware
milos@cnc:~$ sudo apt purge raspi-firmware
  raspi-firmware*
2 not fully installed or removed.
/etc/kernel/postinst.d/zz-update-grub:
Generating grub configuration file ...
Found background image: /usr/share/images/desktop-base/desktop-grub.png
Found linux image: /boot/vmlinuz-6.1.0-40-rt-amd64
Found initrd image: /boot/initrd.img-6.1.0-40-rt-amd64
Found linux image: /boot/vmlinuz-6.1.0-30-rt-amd64
Found initrd image: /boot/initrd.img-6.1.0-30-rt-amd64
Warning: os-prober will not be executed to detect other bootable partitions.
Systems on them will not be added to the GRUB boot configuration.
Check GRUB_DISABLE_OS_PROBER documentation entry.
done
Setting up linux-image-rt-amd64 (6.1.153-1) ...
Purging configuration files for raspi-firmware (1.20220830+ds-1) ...
First time that I don't see any error. Are we out of the woods now?
Time to create page: 0.348 seconds
