2.9.5 should not be available to download due to it being broken.
25 Oct 2025 21:26 #337166
2.9.5 should not be available to download due to it being broken. was created by andypugh
2.9.6 is also broken.
And 2.9.5 and 2.9.6 only exist because 2.9.4 is broken.
As it 2.9.3, 2, 1, 0....
As far as I know at the moment 2.9.7 is, at least, broken in unknown ways.
It will be out on Sunday.
The following user(s) said Thank You: tommylight, pommen
- unknown
- Thank you received: 323
26 Oct 2025 01:47 #337173
by unknown
Replied by unknown on topic 2.9.5 should not be available to download due to it being broken.
Any idea of what may be suitable for a new image ?
I'd like an idea of what to use in the Raspios image I'm working on for Trixie.
- Thank you received: 2177
26 Oct 2025 05:59 #337181
Replied by Aciera on topic 2.9.5 should not be available to download due to it being broken.
2.9.7
The following user(s) said Thank You: unknown
- Thank you received: 4153
27 Oct 2025 10:58 #337274
Replied by rodw on topic 2.9.5 should not be available to download due to it being broken.
DO we actually need an image anymore of the Pi is using Trixie? Why not just try one of the official Deb files here?
linuxcnc.org/dists/trixie/2.9-uspace/binary-arm64/
- unknown
27 Oct 2025 11:59 - 27 Oct 2025 23:09 #337275
by unknown
I think those Trixie files may have been built on Bookworm, when I built an image last night it pulled the Linuxcnc packages from Debian. Trying to manually install brought up a lot of messages regarding packages that could not be installed.
sudo apt install linuxcnc-uspace=1:2.9.6 linuxcnc-uspace-dev=1:2.9.6
Solving dependencies... Error!
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
Unsatisfied dependencies:
linuxcnc-uspace : Depends: python3 (< 3.12) but 3.13.5-1 is to be installed
Depends: libboost-python1.74.0 (>= 1.74.0+ds1) but it is not installable
Depends: libboost-python1.74.0-py311 but it is not installable
Depends: libgpiod2 (>= 1.5.1) but it is not installable
Depends: libpython3.11 (>= 3.11.0) but it is not installable
Recommends: hostmot2-firmware-all but it is not installable
Error: Unable to correct problems, you have held broken packages.
Error: The following information from --solver 3.0 may provide additional context:
Unable to satisfy dependencies. Reached two conflicting decisions:
1. linuxcnc-uspace:arm64=1:2.9.6 is selected as an upgrade
2. linuxcnc-uspace:arm64=1:2.9.6 Depends python3 (< 3.12)
but none of the choices are installable:
[no choices]
Last edit: 27 Oct 2025 23:09 by unknown.
28 Oct 2025 06:43 #337326
Thars a shame, So much going on in the builds and repos
- unknown
28 Oct 2025 10:02 #337341
by unknown
Aye, that it is.
29 Oct 2025 09:25 #337388
www.linuxcnc.org/linuxcnc-trixie-install.sh
But he wants to produce a singe script that does all Debian versions....
Andy is working hard on this, He's got a longer key now for trixie. you could try this script he did for trixieAye, that it is.
- unknown
29 Oct 2025 10:54 #337391
by unknown
The image builds with the longer Trixie key, I've also migrated to the newer form for the sources list.
The only package that will update from the Linuxcnc repo are the docs. So it works, the only issue being the one mentioned in my previous post.
30 Oct 2025 11:32 #337471
I think you need a preferences file to pin the linuxcnc repo files in /etc/apt/preferences.d that looks something like
github.com/LinuxCNC/linuxcnc-live-build/...c-uspace.pref.chroot
Time to create page: 0.732 seconds
