2.9.5 should not be available to download due to it being broken.
30 Oct 2025 11:52 #337474 by unknown
The post I put earlier was from trying to install the package manually, by
sudo apt install linuxcnc-uspace=1:2.9.7
Trying to install from the Linuxcnc repos would break the build. And to be honest I think the Release may only reference the doc files. I'd have to check my notes for sure on that one. I may be wrong but I remember having a look through it.
  • andypugh
  • andypugh's Avatar Topic Author
  • Moderator
  • Moderator
14 Nov 2025 21:29 #338397 by andypugh
We also now have packages being built by Github.
github.com/LinuxCNC/linuxcnc/releases/tag/v2.9.7
14 Nov 2025 23:03 #338407 by rodw
When will GitHub start building versions for 2.10/master branch? It really is necessary.
14 Nov 2025 23:41 #338412 by unknown
Most people expect to be able to install packages just usually apt or apt-get, as far as I know github doesn't provide the resources to host a git repo.
  • Moderator
  • Moderator
14 Nov 2025 23:58 #338416 by tommylight
I use a lot of software from GitHub, namely the appimage stuff like FreeCAD, OrcaSlicer, OpenRGB, OBS-Studio, LosslessCut, LMMS, even Inkscape sometimes, and this has nothing to do with the above, but a few years back i did try to do a LinuxCNC appimage, it did not go well, so i gave up.
Yes i am aware it would not work for machine control unless the RT kernel is active on the system, but i was content with sim only back then. Given the amount of wasted time, building from sources is a breeze.
On the other side of the same coin, whenever a new version of Linux Mint came up, the first thing i did was download all deb versions from buildbot and try installing them, i do try version from all distros, new and old, usually does not work, but with some other Linux distros it did work like Ubuntu something or another that worked with (what was before BookWorm?) debs.
Moral of the story: build from sources, remaster the ISO, move on! :)
This is a huge timesaver as i have most of the machines using Mint 19.3, so any drive failure takes about 10 to 30 minutes to fix. One of those thing that are rarely needed, but very nice to have.
  • Moderator
  • Moderator
14 Nov 2025 23:59 #338418 by tommylight
... as far as I know github doesn't provide the resources to host a git repo.
I am confused ! :)
15 Nov 2025 00:01 #338419 by unknown
I meant deb repo.
15 Nov 2025 00:22 #338420 by rodw
no but a script could copy new versions from git releases to the existing LinuxCNC Deb repository
  • andypugh
  • Moderator
  • Moderator
15 Nov 2025 01:24 #338425 by andypugh
It shouldn't be necessary....
But it _should_ already work, except that Sid isn't building right now so the process fails.
Trial run: github.com/andypugh/linuxcnc-petter/actions
15 Nov 2025 03:07 #338437 by unknown
I not too sure what you mean, Linuxcnc does provide a server with ISO downloads and repos. It has done for many many years.
Actually apt is not stupid, if you ever used a RedHat distro in the 1990's or ealry 2000's you would know that dependencies had to be manually searched and installed. Slackware had the same issue as well, tho it did not have quite the software support a lot of packages had to be built by hand.
debs are a godsend, all dependencies are with the file it self (99.9999% of the time), everything is done automagically.
And honestly to not be able to install the latest packages via apt is really breaking the package system. A machinist may not want to download a script and then run it to install an update, they would prefer a simple way of doing it, apt & apt-get provide that method. And it is insurance from users trying to install packages they shouldn't, apt provides that.
Theres a lot of "behind the scenes" things that are involved in adding a deb package to a repo, it's not just about copying a file. Even when using a proxy to cache debs more things happen than just storing the file.
So before one goes shooting their mouth off, try setup reprepro on a server to provide a repo and have a look at what's involved. Or apt-cacher-ng and see if the files can link to external files.
I don't get why you have such an interest in thing being free. It's a little creepy.
Time to create page: 0.879 seconds
