Suggestions for hardware to build EMC
03 Dec 2010 02:36 #5826
by ldbenge
Suggestions for hardware to build EMC was created by ldbenge
What is the best hardware/chipset/mfr to Install the Ubuntu/EMC2 LiveCD?
AMD/Intel?
Any particular video cards to stick to/stay away from?
I'm building a new PC to replace my old Win2K laptop for my Plasma table, any help is greatly appreciated.
AMD/Intel?
03 Dec 2010 13:22 #5836
by BigJohnT
Replied by BigJohnT on topic Re:Suggestions for hardware to build EMC
The Atom D510MO seems to be well liked and cost effective too.
07 Dec 2010 19:14 #5914
by piasdom
Replied by piasdom on topic Re:Suggestions for hardware to build EMC
any suggestions for a video card?
i can't seem to get one that doesn't throw
my latency to over 300,000. Thanks
07 Dec 2010 20:48 #5917
by ldbenge
Replied by ldbenge on topic Re:Suggestions for hardware to build EMC
How do most people vent for heat in the computer box? With filters and fans?
I wonder about maintaining the integrity of the motherboard/etc in that tough environment.
07 Dec 2010 22:00 #5921
by jmelson
Replied by jmelson on topic Re:Suggestions for hardware to build EMC
Years ago, I built a custom computer for my first EMC system, that was about 1998. I used a computer-type fan with a bezel and screen salvaged from some old gear. I added a foam filter sold at the hardware store for replacement for window air conditioners. It is about a 1/8" thick open-cell foam. This worked well, and when that computer was retired, the inside of the box was still very clean. The fan blew air into the enclosure, so it pressurized the box to prevent ingress of dirt.
Jon
Jon
16 Dec 2010 03:49 #6070
by ldbenge
I have a Frankenstein PC put together, Ubuntu 10.04 LTS loaded
running apt-get install emc2 I get some failed dependencies...
any ideas?
The following packages have unmet dependencies:
emc2: Depends: python (< 2.6) but 2.6.5-0ubuntu1 is to be installed
Depends: python2.5-glade2 but it is not installable
Depends: python2.5-gnome2 but it is not installable
Depends: python2.5-imaging but it is not installable
Depends: python2.5-tk but it is not installable
Recommends: hostmot2-firmware but it is not installable
E: Broken packages
any ideas?
E: Broken packages
16 Dec 2010 04:16 #6071
by ldbenge
I was able to downlevel python to 2.5.5, still getting same error.
I guess I will just download the Live-CD provided on this site.
Anyone had similar issues trying to install the packages separate?
16 Dec 2010 12:55 #6076
by BigJohnT
I always start with the LiveCD and only go other routes if the particular computer has problems with loading from the LiveCD.
As for cooling the D510MO is a fan-less motherboard and could be in a sealed box I assume so long as the ambient temperature is not too high. Also it has built in video so no video card is needed. I built a complete D510MO system with19" monitor, 4gb memory, 800gb hard drive and dvd drive for $350 a couple of weeks ago then saw on NewEgg a special that would have saved me $25 more on the motherboard/memory combo. With the "green" hard drive this system is totally quiet as long as the DVD drive is not reading a disk.
My latency running for 24 hours has never reached 10,000 on the D510MO
16 Dec 2010 22:37 #6078
by ldbenge
First time I tried the LiveCD I got an error on install and failed.
I'm trying again but I burned a second cd and both show 1 error on disc before I even install?
17 Dec 2010 18:06 #6098
by BigJohnT
Did you burn it as an image and not just copy the files like is explained in the getting started guide?
Time to create page: 0.093 seconds
