Suggestions for hardware to build EMC
18 Dec 2010 03:25 #6124
by hcb
Replied by hcb on topic Re:Suggestions for hardware to build EMC
Hey, John, I looked up that motherboard and it's certainly cheap enough but what are you using for a parallel port on it?
Thank you for your time and help.
Merry Christmas.
--HC
Merry Christmas.
--HC
18 Dec 2010 07:07 #6127
by ldbenge
Replied by ldbenge on topic Re:Suggestions for hardware to build EMC
Yes sir, iso image>cd
It ended up being speed disc was burned; slowed to 8x
Now I got video card probs; Ubuntu doesnt like any of the 3 cards Ive tried. The screen is either black or flickers almost sending me into a seizure.
It calmed down a bit when I loaded proprietary driver; but Latency Test doesnt look too good
I might just build the Atom rig; but I require 2 COM ports...
1 for torch height control
1 for xyz
What do you suggest?
1 for xyz
18 Dec 2010 12:58 #6134
by BigJohnT
Replied by BigJohnT on topic Re:Suggestions for hardware to build EMC
hcb wrote:
You could use it for extra I/O if needed. I'm not using mine atm for anything.
Merry Christmas.
--HC
18 Dec 2010 17:59 #6142
Replied by andypugh on topic Re:Suggestions for hardware to build EMC
hcb wrote:
It has an onboard parallel port on a header rather than a back panel connector. This is ideal for connection to a Mesa 7i43, and no real problem if you are hard-wiring to equipment in the same box. Otherwise you need a Parallel port header adapter, they are not expensive.
cgi.ebay.com/25pin-Parallel-25pin-Header...t-Plat-/110593994600
19 Dec 2010 01:17 #6152
by hcb
Hey, John, thank you for the reply. I had thought the board did NOT have a parallel port at all (a mistake on my part because I looked at the picture and did not see one) so my question was asking what you installed into the system to give it a parallel port, not what you were using it for. Again, it's my fault, I looked at the picture but did not read the technical details about I/O ports. Andy posted after you and pointed out a parallel port adapter for the back panel and pointed out that it has one but on a header which clarified things for me greatly.
I'm sorry for my confusion.
--HC
--HC
19 Dec 2010 02:10 #6153
by hcb
Andy, thank you for your reply, it clarified things for me. As I posted in response to John, I made a mistake and just looked at the picture of the motherboard, not the description (particularly from Intel's site) which shows it to have a parallel port via header.
I looked at the link to eBay (thank you) and, as it turns out, I have about 10 those things in a box from 1996-1998 when I used to build computers for a company. They look largely the same...except they have a PS2 port on them as well, but on a different cable. Suite!
Thanks again for your post, I made a mistake but you cleared it up.
--HC
--HC
Time to create page: 0.139 seconds
