OK
I have given up on making it work after messing up several versions of my hals and inis
Instead i now want to make new ones by using mesaCT like i did from the beginning (the way that so far let me get the most successfull result)
I get an "OK" when trying to test the configuration
But when building the configuration i get this message from meseCT:
File "../../usr/lib/python3/dist-packages/libmesact/buildconfig.py", line 61, in build
parent.updateini.update(parent, iniFile)
File "../../usr/lib/python3/dist-packages/libmesact/updateini.py", line 135, in update
self.update_key(item[0], item[1], item[2])
File "../../usr/lib/python3/dist-packages/libmesact/updateini.py", line 765, in update_key
start = self.sections[f'[{section}]'][0]
KeyError
'[MESA]'
First download the deb and reinstall
to be sure you have the latest build date
Then please file an issue at
github.com/jethornton/mesact/issues
