Linuxcnc 2.9.4 and Mesa 7i97T
- Nkbhvid
26 Jan 2026 17:55 #341963
by Nkbhvid
Linuxcnc 2.9.4 and Mesa 7i97T was created by Nkbhvid
Hi
Coming from my safe world of Mach 3 and 4 I have now made the jump into Linuxcnc.
OMG its complicated!
I have spend almost a week trying to set up Linuxcnc 2.9.4 (and a couple of other versions) on the mesa 7i97T card.
Is there anybody out there who has made this work?
I can make it ping but thats as far as I can get. From here there is only "board not found"
Is there any known challenges in this setup and will it ever work?
Best regards
Nicolaj Hvid
Best regards
Nicolaj Hvid
- Thank you received: 5326
26 Jan 2026 18:17 - 26 Jan 2026 18:19 #341964
Replied by PCW on topic Linuxcnc 2.9.4 and Mesa 7i97T
What IP address is selected on the 7I97T?
What does the command:
ip a
return?
ip a
return?
Last edit: 26 Jan 2026 18:19 by PCW.
- Nkbhvid
26 Jan 2026 19:25 #341966
by Nkbhvid
Replied by Nkbhvid on topic Linuxcnc 2.9.4 and Mesa 7i97T
The ip is 10.10.10.10
I can ping it.
return of ip a:
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000
link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
inet 127.0.0.1/8 scope host lo
valid_lft forever preferred_lft forever
inet6 ::1/128 scope host noprefixroute
2: enp4s2: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc fq_codel state UP group default qlen 1000
link/ether 00:01:02:f1:ea:a1 brd ff:ff:ff:ff:ff:ff
inet 10.10.10.1/8 brd 10.255.255.255 scope global noprefixroute enp4s2
inet6 fe80::74db:6330:9bad:59ef/64 scope link noprefixroute
3: enp3s0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc fq_codel state UP group default qlen 1000
link/ether 90:2b:34:64:01:44 brd ff:ff:ff:ff:ff:ff
inet 192.168.1.85/24 brd 192.168.1.255 scope global dynamic noprefixroute enp3s0
valid_lft 3522sec preferred_lft 3522sec
inet6 2001:2012:18ac:2400:a697:d340:a244:6b59/64 scope global temporary dynamic
valid_lft 288sec preferred_lft 288sec
inet6 2001:2012:18ac:2400:922b:34ff:fe64:144/64 scope global dynamic mngtmpaddr noprefixroute
inet6 fe80::922b:34ff:fe64:144/64 scope link noprefixroute
I can ping it.
return of ip a:
26 Jan 2026 19:38 #341967
What program does not recognize the card?
- Nkbhvid
26 Jan 2026 23:28 #341974
by Nkbhvid
I am not sure I understand your question?
This is my last attempt to make it work after having spend days trying to figure out how to configure Linuxcnc to work with my Mesa 7i97T.
So far it has been a nightmare -expensive in time and money.
- unknown
- Thank you received: 323
26 Jan 2026 23:42 #341975
by unknown
Replied by unknown on topic Linuxcnc 2.9.4 and Mesa 7i97T
Does mesaflash see the card ?
Usually in these situations it is help to attach your ini & hal files and the error reports from when Linuxcnc fails.
27 Jan 2026 04:17 - 27 Jan 2026 04:18 #341985
I was asking about:
What program printed that message?
As Unknown mentioned, posting your hal and ini files would help diagnosis.
Note that pncconf cannot currently make configuration files for the 7I97/7I97T
so the options are to use MesaCT or start with a sample 7I97 configuration
and modify it to suit your hardware:
Last edit: 27 Jan 2026 04:18 by PCW.
- Nkbhvid
27 Jan 2026 16:44 #342006
by Nkbhvid
Correct me if im wrong here but as far as im informed there will be no ini nor hal file before the configuration?
Since im not there yet i have none of them - or at least from what i can see
I can ping the board and mesaflash sees it but thats about it.
I'm really curious to hear if my setup with a Linuxcnc and a mesa 7i97T is a dead end street. If so I would rather stop now and go back to my safe world of PLCs and Mach
- Nkbhvid
27 Jan 2026 17:05 #342008
by Nkbhvid
Here are some (random) results
ping 10.10.10.10
PING 10.10.10.10 (10.10.10.10) 56(84) bytes of data.
64 bytes from 10.10.10.10: icmp_seq=1 ttl=64 time=0.124 ms
64 bytes from 10.10.10.10: icmp_seq=2 ttl=64 time=0.089 ms
64 bytes from 10.10.10.10: icmp_seq=3 ttl=64 time=0.092 ms
64 bytes from 10.10.10.10: icmp_seq=4 ttl=64 time=0.096 ms
^C
--- 10.10.10.10 ping statistics ---
4 packets transmitted, 4 received, 0% packet loss, time 3060ms
rtt min/avg/max/mdev = 0.089/0.100/0.124/0.013 ms
mesaflash --device ethernet --addr 10.10.10.10 --readhmid
No ETHERNET board found
ls /lib/firmware/hm2/
3x20-1 4i65 4i68 5i20 5i22 5i22-1 5i22-1.5 5i23 7i43 7i43-2 7i43-4 7i97t_d.bin
Unsupported ethernet device 7I97T at 10.10.10.10
ping 10.10.10.10
^C
- unknown
27 Jan 2026 18:04 - 27 Jan 2026 18:05 #342010
by unknown
What version of mesaflash are you using ?
forum.linuxcnc.org/27-driver-boards/5285...-by-mesaflash#302114
Maybe of some help
Maybe of some help
Last edit: 27 Jan 2026 18:05 by unknown.
Time to create page: 0.316 seconds
