Linuxcnc 2.9.4 and Mesa 7i97T
07 Feb 2026 16:44 #342610 by PCW
Replied by PCW on topic Linuxcnc 2.9.4 and Mesa 7i97T
That typically means a connection issue
Either the link was not up when LinuxCNC started, the IP address was wrong or similar
  • Moderator
  • Moderator
07 Feb 2026 17:44 #342611 by tommylight
Replied by tommylight on topic Linuxcnc 2.9.4 and Mesa 7i97T
In a terminal, what does
ip a
return?
08 Feb 2026 11:45 #342648 by Nkbhvid
Replied by Nkbhvid on topic Linuxcnc 2.9.4 and Mesa 7i97T
It seems that the connection is ok
mesact finds and recognizes board
ip a return
BROADCAST, MULTICAST, UP, LOWER_UP at 10.10.10.10
08 Feb 2026 11:47 - 08 Feb 2026 13:48 #342649 by Nkbhvid
ip a:
File Name: ipareturn.txt
File Size:1 KB
Last edit: 08 Feb 2026 13:48 by Nkbhvid.
08 Feb 2026 13:55 #342653 by Nkbhvid
OK
I have given up on making it work after messing up several versions of my hals and inis
Instead i now want to make new ones by using mesaCT like i did from the beginning (the way that so far let me get the most successfull result)
I get an "OK" when trying to test the configuration
But when building the configuration i get this message from meseCT:
File "../../usr/lib/python3/dist-packages/libmesact/buildconfig.py", line 61, in build
    parent.updateini.update(parent, iniFile)
  File "../../usr/lib/python3/dist-packages/libmesact/updateini.py", line 135, in update
    self.update_key(item[0], item[1], item[2])
  File "../../usr/lib/python3/dist-packages/libmesact/updateini.py", line 765, in update_key
    start = self.sections[f'[{section}]'][0]
KeyError
'[MESA]'
First download the deb and reinstall
to be sure you have the latest build date
Then please file an issue at
github.com/jethornton/mesact/issues
12 Feb 2026 21:29 #342864 by Nkbhvid
Finally I made a successfull connection of the mesa 7i97t.
When I turn the motor still standing on the table i can see the X Dro increase in numbers to what could be expected in relation to the counts/rev.
Now two things are still beyond my understanding.
1. When I try to jog the axis the DRO only moves 0,18mm when pressing and releasing the < or > key. Same result if I use arrows in AXIS. Jog mode is set to continuous.
2. When I release Estop and enable the drive F1 & F2 the motor starts rotating at a speed which looks like something that could be1v.
Any explanations?
HAL file attached
File Name: main.txt.hal
File Size:3 KB
  • Moderator
  • Moderator
12 Feb 2026 22:09 #342865 by tommylight
Time to create page: 0.196 seconds
