Linuxcnc 2.9.4 and Mesa 7i97T
- Thank you received: 7478
28 Jan 2026 00:31 #342047
Replied by tommylight on topic Linuxcnc 2.9.4 and Mesa 7i97T
No need for a bit file, only if you need non standard firmware.
That is from old Mesa boards that needed the firmware at startup, all new ones have that on board, many of them twice, just in case a bad flash messes up switch to the backup and flash again, correctly if possible.
- Nkbhvid
28 Jan 2026 17:01 #342088
by Nkbhvid
Replied by Nkbhvid on topic Linuxcnc 2.9.4 and Mesa 7i97T
Again -thanks for life-saving support on this issue
I have now a mesa 7i97T connected to my Linuxcnc and according to mesaCT everything seems to be ok.
Now I'm ready for the next chapter:
Configuring Linuxcnc for the analog setup with my Rexroth ECOdrive.
The plan is to let the ECOdrive make the encoder loop between drive and motor encoder, and not loop back to LinuxCNC due to the lack of encoder signals hand over from ECOdrive.
So, is there any directions or previous discussions about this topic here in the Forum?
- Thank you received: 5326
28 Jan 2026 20:05 #342096
Replied by PCW on topic Linuxcnc 2.9.4 and Mesa 7i97T
Unfortunately, that will not work, analog commanded drives require position feedback to LinuxCNC.
- Nkbhvid
28 Jan 2026 21:05 #342099
by Nkbhvid
Maybe mesa 7i97t will not work without position feedback but it’s far from uncommon that woodworking cncs run this way.
28 Jan 2026 21:36 #342100
Its not a 7I97T limitation, it's a system limitation.
Analog servo drives for CNC do not use the analog voltage for position control
but rather torque or velocity control. This means the control system (LinuxCNC in this case)
MUST get position feedback from the axis or it cannot control the axis position.
- Nkbhvid
28 Jan 2026 21:49 #342101
by Nkbhvid
The ECOdrive DKC11.3 can actually output both Incremental Encoder Output (A/B/Z Emulation) as well as SSI absolute encoder emulation. Will any of these fit the encoder input of mesa7i97?
28 Jan 2026 21:55 - 28 Jan 2026 21:57 #342103
Yes, if the the drive can output quadrature (A,B,Z) that can connect directly to the 7I97T's encoder inputs
SSI is also possible but would require an additional daughtercard, so quadrature is easier.
Last edit: 28 Jan 2026 21:57 by PCW.
- Nkbhvid
28 Jan 2026 22:07 #342105
by Nkbhvid
Quadrature A,B and Z should be the standard of the ecodrives position signal.
Could you direct me to some knowledge resources or forum threads related to the setup?
28 Jan 2026 22:36 #342107
Link posted earlier in this thread:
forum.linuxcnc.org/9-installing-linuxcnc...i97t?start=10#342029
- Nkbhvid
04 Feb 2026 14:33 #342386
by Nkbhvid
I've finally managed to configure my 7i97t with the mesaCT.
In order to test my card I tried to put a small voltage on the output pin of the analog 0.
I would have expected to be able to use something like
setp hm2_7i97.0.analogout0 1.0
but it seems that the parameter for the analog drives doesnt exist at all?
My firmware is 7i97_d.bin
Where did i get lost this time?
Time to create page: 0.554 seconds
