Installing Linuxcnc on new pc Using Debian 12.13 and Linuxcnc 2.9.8 mesa 7i76eu
18 Mar 2026 14:47 #344463 by georgio
Thank you for your response PCW. I have checked and there is field power of 24v across pins 1&8 it is also tranfered to the nearby power block can't remember its tb number but done as mentioned in posts and manuals.
18 Mar 2026 15:05 #344464 by georgio
I just figured out what the gpio pins are and they are if iam correct the 50 pins on P1 and P2 halshow was not showig any sserial port pins. That is probably why the pin do not exist errors I was getting is from.
Just a thought
18 Mar 2026 15:31 #344467 by PCW
When you say you have an error,
Please please copy/paste that error
in your post.
It's nearly impossible to diagnose the issue
without accurate error reporting.
Also do you have a red LED (CR11) illuminated
above the Spindle connection (TB4) ?
18 Mar 2026 17:01 #344468 by georgio
Hi PCW,
I have attached the linuxcnc report. I put it for line 36 in hal but all of the other inputs 05-09 were the same errors. No there aren't any red led's on the board at that location with the error i get there will be one in amonst the boot up led's.
18 Mar 2026 17:07 #344469 by PCW
Before you start LinuxCNC, does red LED CR11 (above TB4) Illuminate?
18 Mar 2026 17:18 #344472 by georgio
no it never lights,
thanks
18 Mar 2026 17:29 #344473 by PCW
OK that means you have no VIN so the field I/O section is unpowered
Normally VIN comes from VFIELD (W1 LEFT)
So either you have:
1.  No VFIELD
2. W1 is in the right hand position (it should be in the default left position)
3. Some hardware issue with the field I/O section.
18 Mar 2026 17:32 #344474 by georgio
W1 is in the default position left and the fileld power is correctly conneced
George
18 Mar 2026 18:02 #344476 by PCW
If you measure from
TB1 pin 8 (-) to TB1 PIN 5 (+)
 What do voltage do you get?
18 Mar 2026 18:10 #344477 by georgio
Time to create page: 0.662 seconds
