live disk asking for "login"
04 Apr 2011 20:11 #8528 by alexr
Replied by alexr on topic Re:live disk asking for
:~/Downloads$ ./emc2-install.sh
gpg: requesting key 8F374FEF from hkp server pgpkeys.mit.edu
gpg: key 8F374FEF: "EMC Archive Signing Key <This email address is being protected from spambots. You need JavaScript enabled to view it.>" not changed
gpg: Total number processed: 1
gpg: unchanged: 1
OK
Hit www.linuxcnc.org lucid Release.gpg
Ign www.linuxcnc.org/emc2/ lucid/base Translation-en_AU
Ign www.linuxcnc.org/emc2/ lucid/emc2.4 Translation-en_AU
Hit au.archive.ubuntu.com lucid Release.gpg
Get:1 au.archive.ubuntu.com/ubuntu/ lucid/main Translation-en_AU [1,813B]
Hit security.ubuntu.com lucid-security Release.gpg
Ign security.ubuntu.com/ubuntu/ lucid-security/main Translation-en_AU
Ign security.ubuntu.com/ubuntu/ lucid-security/restricted Translation-en_AU
Get:2 au.archive.ubuntu.com/ubuntu/ lucid/restricted Translation-en_AU [2,407B]
Ign au.archive.ubuntu.com/ubuntu/ lucid/universe Translation-en_AU
Get:3 au.archive.ubuntu.com/ubuntu/ lucid/multiverse Translation-en_AU [91.6kB]
Ign security.ubuntu.com/ubuntu/ lucid-security/universe Translation-en_AU
Ign security.ubuntu.com/ubuntu/ lucid-security/multiverse Translation-en_AU
Ign www.linuxcnc.org lucid/base Packages
Hit security.ubuntu.com lucid-security/main Packages
Hit au.archive.ubuntu.com lucid-updates Release.gpg
Ign au.archive.ubuntu.com/ubuntu/ lucid-updates/main Translation-en_AU
Ign au.archive.ubuntu.com/ubuntu/ lucid-updates/restricted Translation-en_AU
Ign au.archive.ubuntu.com/ubuntu/ lucid-updates/universe Translation-en_AU
Ign au.archive.ubuntu.com/ubuntu/ lucid-updates/multiverse Translation-en_AU
Ign www.linuxcnc.org lucid/emc2.4 Packages
Ign www.linuxcnc.org lucid/base Sources
Hit au.archive.ubuntu.com lucid/main Packages
Hit au.archive.ubuntu.com lucid/restricted Packages
Hit au.archive.ubuntu.com lucid/main Sources
Hit au.archive.ubuntu.com lucid/restricted Sources
Hit security.ubuntu.com lucid-security/restricted Packages
Hit security.ubuntu.com lucid-security/main Sources
Hit security.ubuntu.com lucid-security/restricted Sources
Hit security.ubuntu.com lucid-security/universe Packages
Hit security.ubuntu.com lucid-security/universe Sources
Hit security.ubuntu.com lucid-security/multiverse Packages
Hit au.archive.ubuntu.com lucid/universe Packages
Hit au.archive.ubuntu.com lucid/universe Sources
Ign www.linuxcnc.org lucid/emc2.4 Sources
Hit au.archive.ubuntu.com lucid/multiverse Packages
Hit au.archive.ubuntu.com lucid/multiverse Sources
Hit au.archive.ubuntu.com lucid-updates/main Packages
Hit au.archive.ubuntu.com lucid-updates/restricted Packages
Hit au.archive.ubuntu.com lucid-updates/main Sources
Hit au.archive.ubuntu.com lucid-updates/restricted Sources
Hit au.archive.ubuntu.com lucid-updates/universe Packages
Hit au.archive.ubuntu.com lucid-updates/universe Sources
Hit au.archive.ubuntu.com lucid-updates/multiverse Packages
Hit au.archive.ubuntu.com lucid-updates/multiverse Sources
Hit security.ubuntu.com lucid-security/multiverse Sources
Hit www.linuxcnc.org lucid/base Packages
Hit www.linuxcnc.org lucid/emc2.4 Packages
Hit www.linuxcnc.org lucid/base Sources
Hit www.linuxcnc.org lucid/emc2.4 Sources
Fetched 95.8kB in 4s (20.1kB/s)
Reading package lists... Done
Building dependency tree
Reading state information... Done
Package emc2 is not available, but is referred to by another package.
This may mean that the package is missing, has been obsoleted, or
is only available from another source
E: Package emc2 has no installation candidate
this is the error report from terminal
any help here would be colossal
04 Apr 2011 21:13 #8531 by andypugh
Replied by andypugh on topic Re:live disk asking for
alexr wrote:
Did i miss something or are the image and headers there? i couldnt find any?
I might be missing something, but I just downloaded rtai-3.8.tar.bz2 and the patch files seemed to be there (base/arch/i386/patches) and lots of other stuff too.
I have no idea how you work out which version you need for any given linux kernel though.
05 Apr 2011 07:58 #8538 by Mike_Eitel
Replied by Mike_Eitel on topic Re:live disk asking for
Hi alexr
I know, a silly hint, but I have had crazy effects with a specific keyboard that works well on all other pc's .....
A thin client was not able to boot linux...... and went mad...
Mike
05 Apr 2011 08:34 #8539 by alexr
I have been there. RTAI package is provided in a tarball but no image and header to be found or that i can find following install procedure.
All i have done is in one of my other threads a few requests down.
last time i just downloaded them off synaptic but they arent there any more, im talking to the rtai crew to see whats happening
in the mean time i am trying other solutions.
thank you for your input though appreciated
05 Apr 2011 09:03 #8540 by alexr
ANSWER FOUND!!!!
Solution #1
help.ubuntu.com/community/LiveCD
Figure 4: Just press enter to get past this, or let it time-out
this actually works!
Solution #2
What I had done was press ESC to view runtime info when livecd was loading
and I found this
"GLIB ERROR getpwid_r (): unable to run due to unknown user ID" (bios set tocd only boot no hdds attached to Mainboard)
I pressed enter and it came up with "(0)"
the old login splash had about five options on a purple splash screen ( original boot screen, and it looks very professional)
After waiting for Livecd to load (and doing the above); a new option screen came up with "try ubuntu without installing" and another option "install ubuntu" in a WINDOW like view.
boots up like this every time now! even with original bios settings, hdds plugged in and grub with ubuntu / windows multiboot unmodified.
HERE is everything i did before finding solutions:
changed bios settings to cd boot with hdds in and nothing disabled
tried livecd disk without installing and got login prompt (stuck)
reset
changed bios settings to cd boot with hdds disabled
reset
reset.
changed bios settings to cd boot with hdds disabled and turned off to unplug hdds
turned back on
reset
changed everything back to original state, plugged every thing back in and did some more research after posting here for the first time
2days later...............
found the above solution #1
found solution #2 by complete accident
and that folks is how i got my livecd to work, now thats what i call a happy ending :laugh:
05 Apr 2011 11:45 #8550 by BigJohnT
I'm sure glad you sorted this out and shared what you found.
09 Aug 2015 22:04 #61242 by dagrende
To simply all above: if you get a login dialog when booting the live cd: use username ubuntu with empty password.
Time to create page: 0.295 seconds
