Voron Life , for anyone going into 3D printing !
04 Feb 2025 19:41 #320642 by anton610
yes! built with canbus. saves a lot of cables and is easy to implement.
The following user(s) said Thank You: my1987toyota
  • tommylight's Avatar Topic Author
  • Moderator
  • Moderator
04 Feb 2025 19:47 #320644 by tommylight
Replied by tommylight on topic Voron Life , for anyone going into 3D printing !
No and not planing to, the "influencer's" keep forgetting to tell us just what headache that is. It fails, a lot.
As it is, using the USB is enough liability, adding another set of comms is really asking for trouble.
04 Feb 2025 21:24 #320658 by my1987toyota
Replied by my1987toyota on topic Voron Life , for anyone going into 3D printing !
I think I will put a pin in that route for a "try later" when the machine is dialed in and running properly.
I have seen some of the influencers comment on it, as a not for the novice crowd. It's a shame MESA
doesn't make a 3D printer controller board. But I guess that would also mandate a major add-on to
LinuxCNC. Oh well hope springs eternal.
  • Moderator
  • Moderator
04 Feb 2025 22:30 #320667 by tommylight
It's not the board, it's Klipper.
Any board will work for 3D printing and any old PC, not just RPI (i was p.o. at those influencers that always started with "you need a RPI..." ), i have an Acer tablet attached to one of the Vorons that was never shut down, for over 2 years, that poor Voron is always ready to start printing, even from the phone, even if i am in say Australia (got invited there recently for when it gets hot over there :) ), and no i do not use remote desktops and teamviewer n'stuff, i use telegram, so no open ports and perfectly safe.
It would be blasphemy, but that would require FPGA to run klipper firmware in worst case, or add pressure advance and input shaping to LinuxCNC, or at least a way to set some values and be done with it.
Meaning, use a klipper board to test and get those values for advance and shaping, then plug those in LinuxCNC and live happily ever after.
05 Feb 2025 09:58 #320717 by my1987toyota
HMMM. Let's see, how much I.O. do I need? Might just try that in the future.
  • Moderator
  • Moderator
05 Feb 2025 11:38 #320729 by tommylight
2 for homing, 1 for bed/height/leveling sensor, 2 analog ones for temperature
2 PWM outputs for heaters, 1 for fan ...
that is the minimum required
05 Feb 2025 11:56 #320732 by my1987toyota
The real trick is going to be the many stepper driver ports. 7 in the case of the Vor. 2.4.
  • Moderator
  • Moderator
05 Feb 2025 13:11 #320740 by tommylight
Yes, sorry, did not mention it as that is always implied, normally 4 motors then add as needed.
BTW you can do Voron with just one Z motor and have all side coupled with shafts and pulleys/belts, but that leaves auto squaring/leveling out.
Most of my Vorons have 2 boards, this was very nice for the big one (460x460x1200) as one board is on the gantry and only needs power cable USB cable, while the other board is under taking care of 4 motors and the bed. Any chance i get, i will modify the rest like this, broken cables are the only issues i had with them, ever, due to small radius of cable chains and bad quality cable.
The following user(s) said Thank You: besriworld, my1987toyota
06 Feb 2025 10:03 - 06 Feb 2025 10:57 #320822 by my1987toyota
Wait is your big one set up as a 2.4 or a Trident? Eventually I am looking to build a 2.4 version with a 600mm cubed
work envelope (or bigger). Just not this round. LOL
Last edit: 06 Feb 2025 10:57 by my1987toyota. Reason: because I could
  • Moderator
  • Moderator
06 Feb 2025 12:22 #320827 by tommylight
2.4 with round rods on Y and Z, and 10mm belts, not the usual 6mm.
Time to create page: 0.146 seconds
