Voron Life , for anyone going into 3D printing !
10 Feb 2025 10:50 #321151 by my1987toyota
Replied by my1987toyota on topic Voron Life , for anyone going into 3D printing !
Do you outline your build on YouTube or elsewhere? I am curious on what you used or recommend
for nozzle / hot end.,
  • tommylight's Avatar Topic Author
  • Moderator
  • Moderator
10 Feb 2025 18:41 #321179 by tommylight
Replied by tommylight on topic Voron Life , for anyone going into 3D printing !
Not much on youtube @toma.3d but there are pictures on instagram with same user name @toma.3d
As for nozzle/hotend, all have V6 cold end with Volcano hot end, from 0.4 to 1mm nozzles. Nothing fancy but works properly.
The following user(s) said Thank You: my1987toyota
01 Aug 2025 16:18 - 01 Aug 2025 16:19 #332631 by my1987toyota
Ironically I came back to this thread to recall what was said about the USB/CAN upgrade.
I still haven't finished my 2.4 because of having the X1C going most of the time
and hoping Voron Design would have had the Phoenix released by now. Oh well.it's
always something.
Last edit: 01 Aug 2025 16:19 by my1987toyota.
  • Moderator
  • Moderator
02 Aug 2025 20:56 #332697 by tommylight
Is the Phoenix the 600x600x600 one with cnc machined parts?
If yes, probably will not be released, i recall they mentioned it was made for a client so they might not approve.
Adding my view here, there are 3D models for Voron with 9 or 10mm wide belts, i built one with those at a 460x460x1200mm size, so no need to wait, just print the gantry and toolhead parts for wide belt and size it up as you see fit.
Resizing a Voron is easy, use their wizard on the website, it spits a complete list of parts with actual sizes.
03 Aug 2025 15:19 - 03 Aug 2025 16:00 #332729 by my1987toyota
Good point tommylight Though I may modify the models for CNC machining .
Last edit: 03 Aug 2025 16:00 by my1987toyota. Reason: Failure is not an option it's part of the process
23 Aug 2025 22:03 #333827 by my1987toyota
I just came across this today, very tempting. Albeit it needs some work.
The following user(s) said Thank You: tommylight, besriworld
  • Moderator
  • Moderator
24 Aug 2025 00:10 #333831 by tommylight
Seen that a while back, it is a version of Voron 2.4 but bigger.
I have a bigger Voron with 10mm belts all over and i think i linked to files probably twice till now, they ar eon printables.com under the toma.3d name, just in case.
24 Aug 2025 15:04 #333854 by my1987toyota
Appreciated as always tommylight. I put the response there to show that there are kits now available
when before there were none.
www.fysetc.com/products/venture-xl
  • Moderator
  • Moderator
24 Aug 2025 15:11 #333855 by tommylight
You might want to wait a bit till the hysteria settles down and the price will also settle down with it.
Or some China shop will come up with a much cheaper kit, as they did with Voron 0.1.
At the risk of repeating myself, if you have no parts for 3D printers already, it is much better to buy a kit than to source parts yourself, saves a lot of time and even more frustration. Also, after you finally source everything and build the damn thing, you have plenty of parts that don't fit that you payed for so the only reasonable thing is to buy more parts and build another one... :) That is how i ended up with 5 of Voron 2.4 !!!
24 Aug 2025 15:46 - 24 Aug 2025 15:53 #333857 by my1987toyota
Hilariously the XL is open source  github.com/FYSETC/Venture_XL
I am also curious tommylight , have you used other toolheads with the voron 2.4 like the DragonBurner or
RapidBurner? if so what is your opinion of them?
Last edit: 24 Aug 2025 15:53 by my1987toyota.
Time to create page: 0.491 seconds
