Parallel Port XYYZ Gantry Homing Linuxcnc 2.9.4
1 year 8 months ago #322428 by captain chaos
Homing my greatest bugbear. I simply can't get my head around this one.
I wish to have my new machine home X axis and Z axis using one pin IE pin 11
and the two Y axes  on pin 12.
I would prefer to have the Z axis home before the X.
The 2 Y axes should home together in whichever drive arrives first.
I have tried a number of things but have reverted to this setup.
Any help would be greatly appreciated.
Cheers Paul
1 year 8 months ago #322436 by tommylight
It is not possible to use the same pin for tandem axis homing, but you can use one pin for home_all and the second for home Y2 as in the attached example from a working machine.
The following user(s) said Thank You: captain chaos
1 year 8 months ago #322462 by rodw
Also note how Tommy has used HOME_SEQUENCE to home the Z axis first.
1 year 8 months ago #322467 by captain chaos
yea i have thanks but now have to clean up my ini dos corruptions i did not realise that notepad from wine was used to open my ini file.
Just up graded from 18.04 to 20.04 Ubuntu hoping to get better speed from my machine and it has become a bit of s doze machine.
1 year 8 months ago #322476 by rodw
if you have CRLF as line endings, there is a command line program dos2unix (might need installing) that will clean it up.
In Windows you can use notepad++ and it has settings to talk in linux format (no CR)
1 year 8 months ago - 1 year 8 months ago #322670 by captain chaos
Thanks Rod I had seen your post on that subject earlier.
Now I have been banging my head on setting up NPN NC induct prox switches and one of my concerns is that maybe the parport is faulty or not configured right.
The par port tester in the wiki is broken page 404 not found for the files.
Fortunately I found Big John T's file and script here.
forum.linuxcnc.org/18-computer/4743-parallel-port-tester#4743
Last edit: 1 year 8 months ago by captain chaos. Reason: grammer
Time to create page: 0.225 seconds
