ChatGPT LinuxCNC Assistent
- aDm1N
- Thank you received: 24
13 Apr 2025 11:55 - 13 Apr 2025 12:04 #326223
by aDm1N
ChatGPT LinuxCNC Assistent was created by aDm1N
Has anyone used the wizard yet? The answers and support are good, but the data transfer hasn't been working for days. I've tried all possible options. Has it ever worked? Or is it disabled for whatever reason?
chatgpt.com/g/g-vfeQnX43z-linuxcnc-assistant?ref=img.pt
Last edit: 13 Apr 2025 12:04 by aDm1N.
- Thank you received: 4656
15 Apr 2025 07:37 #326361
Replied by andypugh on topic ChatGPT LinuxCNC Assistent
The URL posted to the mailing list was
chat.openai.com/g/g-vfeQnX43z-linuxcnc-assistant
but I can't check that from work as they are worried I will ask questions that leak data.
- aDm1N
15 Apr 2025 11:34 #326384
by aDm1N
Replied by aDm1N on topic ChatGPT LinuxCNC Assistent
The link for the same Page.
I tested all of the public file services offered; some of the alleged URLs were not assigned; a private FTP server or cloud was allegedly tested positive, but no data arrived.
- aDm1N
18 Apr 2025 12:56 - 18 Apr 2025 13:31 #326617
by aDm1N
I've played around with the wizard a lot and actually put together a good configuration. Unfortunately, LinuxCNC won't start, and after a day of back and forth, I'm pretty frustrated because the AI seems to constantly assume an RTAI kernel and, despite my reminder, can't quite figure out how to use the RT kernel. Attached are the .ini and custom.hal files. How do I modify the files to make it run, or where can I get the specific information?
Last edit: 18 Apr 2025 13:31 by aDm1N.
- aDm1N
18 Apr 2025 13:34 - 18 Apr 2025 13:36 #326622
by aDm1N
Unfortunately I couldn't add anything more, here is the error report from linuxcnc.
Last edit: 18 Apr 2025 13:36 by aDm1N.
- unknown
- Thank you received: 323
18 Apr 2025 18:38 #326642
by unknown
Replied by unknown on topic ChatGPT LinuxCNC Assistent
Problem is here:
Note: Using POSIX realtime
./custom.hal:5: execv(stepgen): No such file or directory
./custom.hal:5: waitpid failed stepgen stepgen
./custom.hal:5: stepgen exited without becoming ready
- royka
- Thank you received: 135
18 Apr 2025 19:18 - 18 Apr 2025 19:40 #326644
by royka
Replied by royka on topic ChatGPT LinuxCNC Assistent
I didn't try it, but I have a good experience with Gemini 2.5 pro to configure (text based) a midi controller with custom firmware just by uploading the manual and explain what I wanted. You could try the same with LinuxCNC, upload the right PDF and tell that this is the manual and explain what you want. If it doesn't give a good result try without the manual but add the right prompts.
In the PDF you can see the result with adding the manual, I didn't look at it throughout but it seems already make more sense. (If you indeed will use remora)
Last edit: 18 Apr 2025 19:40 by royka.
21 Apr 2025 12:47 #326822
This is just wrong (typical AI error?)
stepgen is realtime, and should be loaded with "loadrt"
I would rather expect that the same is true of remora-eth-3.0 (if that even exists)
linuxcnc.org/docs/stable/html/man/man9/stepgen.9.html
# Laden der Kinematik und des Benutzermodus-Stepgen
loadusr -W stepgen
loadusr -W remora-eth-3.0This is just wrong (typical AI error?)
- cakeslob
- Thank you received: 280
21 Apr 2025 16:02 #326838
by cakeslob
Replied by cakeslob on topic ChatGPT LinuxCNC Assistent
whole halfile is wrong. its trying to mix other linuxcnc stepgen with remora
from ai
from a remora example
same with the inputs, its mashing up the other linuxcnc inputs with remora inputs
from AI
remora code
from ai
# Verbinden von Stepgen (Benutzermodus) mit den Achsen
setp stepgen.0.scale [JOINT_0]SCALE
setp stepgen.0.maxaccel [JOINT_0]STEPGEN_MAXACCEL
setp stepgen.0.position-scale [JOINT_0]SCALE
# Joins zu den richtigen Positionen und Feedbacks verbinden
net j0pos-cmd joint.0.motor-pos-cmd => stepgen.0.position-cmd
net j0pos-fb stepgen.0.position-fb => joint.0.motor-pos-fb
net j0enable joint.0.amp-enable-out => stepgen.0.enable
# Stepgen und remora zu den Echtzeit-Threads hinzufügen
addf stepgen.0.update servo-thread
# Den Remora-Modul initialisieren
setp remora.joint.0.pos-cmd 0
# Achsenzuweisung
net x-pos-cmd axis.x.motor-pos-cmd => remora.stepgen.00.position-cmd
net x-pos-fb remora.stepgen.00.position-fb => axis.x.motor-pos-fb
net x-enable axis.x.amp-enable-out => remora.stepgen.00.enable
# load the Remora real-time component
loadrt remora-eth-3.0 PRU_base_freq=500000
# joint 0 setup (X axis)
setp remora.joint.0.scale [JOINT_0]SCALE
setp remora.joint.0.maxaccel [JOINT_0]STEPGEN_MAXACCEL
net j0pos-cmd joint.0.motor-pos-cmd => remora.joint.0.pos-cmd
net j0pos-fb remora.joint.0.pos-fb => joint.0.motor-pos-fb
net j0enable joint.0.amp-enable-out => remora.joint.0.enablesame with the inputs, its mashing up the other linuxcnc inputs with remora inputs
from AI
net lid-switch <= remora.input.16.in
net start-btn <= remora.input.17.inremora code
net X-home remora.input.00
- cakeslob
21 Apr 2025 17:36 #326844
by cakeslob
I dont think it did a single halpin correctly in the file, maybe the arduino one but im not sure.
You should start by not using the entire thing. The thing you generated is essentially a broken version of the default/premade configurations we provide for remora The only thing it actually did was assign signals to the remora IO to add the buttons. The encoder signals arent connected to anything, and many of the parameters in the INI file arent real or connected to anything either, its mixing between joint C and Y, the speeds look insane and most of the ini entries are completely made up
Based on what I assume is the intended halfile, you have barely changed anything from the default remora halfile to begin with.
Compare that file to this one, known good and working
github.com/cakeslob/RRW_LAB/blob/main/Li...olset/remora-xyz.hal
it looks like i didnt upload my lathe config, but ill post that if you promise not to use that ai file
