Setting up a Mesa 7i95T
11 months 1 week ago - 11 months 1 week ago #338721 by PCW
Replied by PCW on topic Setting up a Mesa 7i95T
Mesaflash shows physical pins, and which firmware modules are included
in the current installed firmware. What you need for hal file creation/editing
are hal pins and parameters.
To show all 7I95T hal pins and parameters:
1. Start LinuxCNC
2. In a terminal window type:
halcmd show all hm2
if you want a file containing these pins and parameters (for use as a copy/paste donor file):
halcmd show all hm2 > 7i95pins.txt
For documentation on the modules and their pins and parameters:
man hostmot2
Last edit: 11 months 1 week ago by PCW.
11 months 1 week ago - 11 months 1 week ago #338728 by Ringardy
Replied by Ringardy on topic Setting up a Mesa 7i95T
OK got the file but it tells me a whole lot of nothing i understand.
From what i understand so far is that there are bin files that are pre configured for the board.
Like in the second Picture attached.
In the first picture are what seems to me are such files which are provided by mesa.
Which basicly does nothing for me because i cant look into them or research which does what.
Trying my best to understand and get a hang of things.
Last edit: 11 months 1 week ago by Ringardy.
11 months 1 week ago - 11 months 1 week ago #338733 by PCW
Unless you have an added parallel daughtercard, it's unlikely you need
to change the installed firmware.
Since you are using pncconf that does not directly support the 7I95/7I95T
the list of pin names is useful since in has the names of the isolated inputs
like:
hm2_7i95.0.inmux.00.input-00
and isolated outputs like:
hm2_7i95.0.ssr.00.out-00
are there.
If you do not want to add these by hand to a pncconf created configuration
you could use mesact instead of pncconf, since mesact supports the 7I95/7i95T
directly
The following user(s) said Thank You: Ringardy
11 months 1 week ago #338754 by Ringardy
Ok makes sense.
Could you explain to me why mesa flash is showing so little pins, because from what i can read i have the areas TB1-4 but i dont have the rest (TB5+6).
Do those usualy show or is that normal, may ii have made a mistake at some point?
11 months 1 week ago #338755 by PCW
Mesaflash shows only physical pins on the FPGA
The 7I95T uses multiplexing to reduce the number  of external connections,
so there are many more TB pins than FPGA pins. Also much of the I/O
is differential so have 2 TB pins per FPGA pin.
One example of this multiplexing is the isolated inputs. The 7I95T has
24 isolated inputs but these use only 6 FPGA pins to access.
11 months 1 week ago #338757 by Ringardy
Ah i see ok.
Pins of the FPGA Chip i asume.
So basicly this would be the name of one of the pins ( hm2_7i95.0.inmux.00.input-00  ....input-23)
is there something different to this pin (hm2_7i95.0.inmux.00.raw-input-00) ?
And those are basicly those that i can use as input or output
hm2_7i95.0.gpio.041.in
hm2_7i95.0.gpio.041.in_not (What does that mean)
hm2_7i95.0.gpio.041.out
Sorry for asking so many questions
Time to create page: 0.314 seconds
