Setting up a Mesa 7i95T
11 months 2 weeks ago #338630 by Ringardy
Replied by Ringardy on topic Setting up a Mesa 7i95T
I asume like this ?
11 months 2 weeks ago #338631 by tommylight
Replied by tommylight on topic Setting up a Mesa 7i95T
Left picture NO, back to 10 <<< that is the Mesa card address
Right picture YES, that is the network card address inside your PC
Disconnect and connect the cable again for it to work.
11 months 2 weeks ago #338634 by Ringardy
ok that worked.
But it gives me a different error now, i do understand what it wants from me but thats it (total beginner here Sorry)
Debug file information:
Note: Using POSIX realtime
./Sindre_Mill.hal:86: Signal 'x-pos-fb' can not add OUT pin 'hm2_7i95.0.encoder.00.position', it already has OUT pin 'hm2_7i95.0.stepgen.00.position-fb'
7346
File is attached
if there is any other file you kneed let me know
11 months 2 weeks ago - 11 months 2 weeks ago #338636 by PCW
Replied by PCW on topic Setting up a Mesa 7i95T
Are you intending on using encoder feedback?
If not (and this is an open loop step/dir system), you should not connect
the encoder pins (  like hm2_7i95.0.encoder.00.position ) to the axis feedback
signals (like x-pos-fb )
And vice versa, if you ARE intending to use encoder feedback, you should not connect
the steogen pins (  like hm2_7i95.0.stepgen.00.position ) to the axis feedback
Last edit: 11 months 2 weeks ago by PCW.
11 months 2 weeks ago - 11 months 1 week ago #338639 by Ringardy
Plan is for a closed loop system
Used the pncconf only havent changed anything yet
So far its working now the rest ill have to do by testing
Thanks for the help again
Last edit: 11 months 1 week ago by Ringardy. Reason: Solved
11 months 1 week ago #338718 by Ringardy
Ok got the card running so far, controling a stepper motor is working.
After reading the card via mesaflash well missing a lot of pins
Only have like 57 and there compleatly wrong, was to be expected, it should have in total somewhere around 144 pins.
Unfortunatly i am unable to research what bitfile to load do to lack of documentation from mesa.
Ether im blind ore there is nothing in the docs.(see attachment)
Thanks for helping
Time to create page: 0.438 seconds
