I hate the 7i97T
  • Onkelmat
  • Onkelmat's Avatar Topic Author
  • Premium Member
  • Premium Member
11 Jul 2026 05:24 #347676 by Onkelmat
I hate the 7i97T was created by Onkelmat
Just a short rant how hard it is to setup this freaking card. Pnconfig wizard doesn´t work for it. You have to go the full manual way and it´s already a pain to get Mesa CT running and working. Some python needs to be installed, but thats a chapter by itself already. If you went through all the steps to finally get it recognized by Mesa CT and try to run that config with linuxcnc it doesn´t even find the card and exits with an error that the network isn´t reachable. I hate it so much i´ll throw it in the trash and go back to my 5i25 + 7i77. I´ll get a 5i26 for compability.
11 Jul 2026 06:19 #347677 by tuxcnc
Replied by tuxcnc on topic I hate the 7i97T
A bad workman blames his tools ...
The following user(s) said Thank You: Onkelmat
11 Jul 2026 10:00 #347682 by PCW
Replied by PCW on topic I hate the 7i97T
Here is a sample 7I97/7I97T hal/ini configuration:
File Name: basic7i97_...7-11.zip
File Size:4 KB
There's also an experimental pncconf version that supports the 7I97 you might try:
forum.linuxcnc.org/plasmac/55286-servo-d...ofit?start=10#331289
The following user(s) said Thank You: billykid
11 Jul 2026 10:35 #347685 by billykid
Replied by billykid on topic I hate the 7i97T
Good! I need it too, I just ordered one from Europe to replace my DC servos with Sanyo RS2 ac
11 Jul 2026 10:57 - 11 Jul 2026 11:03 #347687 by tuxcnc
Pnconfig wizard doesn´t work for it. (....)  that config with linuxcnc it doesn´t even find the card and exits with an error that the network isn´t reachable.
I tried pncconf once and only wasted time... But always when I found config similar to my needs I can change those as I want.
This is Windows Philosophies contra Linux Philosophies...
In Linux you can do anything in terminal. You must know some magic words, but always you can find solution.
In Windows you use mouse and click on icons. You can nothing when no icons for click...
BTW. Read carefully error messages. Not always, but mostly they gives solution.
Last edit: 11 Jul 2026 11:03 by tuxcnc. Reason: typo
11 Jul 2026 11:37 #347688 by cmorley
Replied by cmorley on topic I hate the 7i97T
I added the 7i97t code to pncconf in master now.
The following user(s) said Thank You: tommylight, Onkelmat
11 Jul 2026 17:11 #347696 by PCW
That's great!
It does need:
setp   hm2_7i97.0.pwmgen.00.offset-mode 1
and not required but an added feature would be:
setp   hm2_7i97.0.pwmgen.00.dither 1
for all 7I97/7I97T PWMgens
Also a better default PWM frequency would be 48 KHz
11 Jul 2026 19:37 #347698 by cmorley
Done!
Thanks.
  • Onkelmat
  • Premium Member
  • Premium Member
11 Jul 2026 23:17 - 11 Jul 2026 23:57 #347700 by Onkelmat
Replied by Onkelmat on topic I hate the 7i97T
I mean i love the Mesa cards and Linuxcnc, but this card really made me reconsider using Mesa and Linuxcnc. The point where i broke was, after getting it to be recognized by mesaflash and mesact Linuxcnc would tell me network unreachable. This problem followed me through the whole process, either "network unreachable" or "no such device at 192.168.1.121"
EDIT: So far i got it running, but the whole process to get there is tiresome.
Last edit: 11 Jul 2026 23:57 by Onkelmat.
11 Jul 2026 23:55 - 12 Jul 2026 00:05 #347701 by PCW
You need to configure the network on the host for the Mesa card.
Also 192.168.1.121 is not suggested for LinuxCNC use as it's  in
a commonly used NAT range.
Suggested setup is to use the 10.10.10.10 address on the Mesa card
(via the IP address setup jumpers) and set  a static host address of
say 10.10.10.100/24.
At this point you should be able to ping the Mesa card:
ping 10.10.10.10
Last edit: 12 Jul 2026 00:05 by PCW.
Time to create page: 0.136 seconds
