Drivers implementation for ROS - rtt_soem
- Grotius
- Thank you received: 2349
23 Aug 2021 12:12 #218500
by Grotius
Replied by Grotius on topic Drivers implementation for ROS - rtt_soem
I got it working.
The original "unix command wrapper" loadusr [flags] unix-command is not used anymore by hal-core.
Instead you can load the ethercat .xml configuration file with a direct "unix" command like :
$ /opt/hal-core/rtlib/./lcec_conf /opt/hal-core/rtlib/ethercat-conf.xml &
Where "&" is a system flag for "do not lock me"
Now I have to check it again without the "-mieee-fp" compile flags, to make it Rpi4 compatible.
I got it working.
The following user(s) said Thank You: juniorfi
- Grotius
23 Aug 2021 12:47 - 23 Aug 2021 13:20 #218504
by Grotius
Github is updated. github.com/grotius-cnc/hal_core/tree/mai.../components/ethercat
Commits are merged.
Commits are merged.
Last edit: 23 Aug 2021 13:20 by Grotius.
The following user(s) said Thank You: tommylight, juniorfi
- juniorfi
- Thank you received: 4
24 Aug 2021 06:57 #218590
by juniorfi
Replied by juniorfi on topic Drivers implementation for ROS - rtt_soem
I don't have that linuxcnc directory created. Should I have it?
- juniorfi
24 Aug 2021 07:15 #218591
by juniorfi
Great!
I will try it out right now!
I noticed how you implemented the lcec.so "All in one file". Good
Regards
Regards
- Grotius
24 Aug 2021 09:40 #218601
by Grotius
That's a /opt/linuxcnc install from a .deb mirror from linux-pro. It can be used to track down issue's, like the unix command yesterday.
That's retrieved by a "-v" verbose off the original Makefile command.
I hope you get your ethercat running today !
- juniorfi
26 Aug 2021 06:39 #218764
by juniorfi
Everything working here!
EtherCAT is full compatible and with the lasts drives.
Here is the project in case someone is interested in:
github.com/grotius-cnc/hal-core
- Grotius
26 Aug 2021 11:15 - 26 Aug 2021 11:25 #218788
by Grotius
Hi Juniorfi,
Nice !
I was thinking. If you build a hal-core kernel module, programming style like the /components/DoFs module.
Then you could include a c++ header file from the ROS project in the c++ section.
In fact this is then the visa-versa interface between hal-core and ROS.
Then you don't have to use any ROS glue code?
If you use a matching c array[100~500] in Ros c++ and in hal-core "extern c", you can pass values visa-versa.
Another thing that could improve the ROS performance is to call the ROS program from hal-core at a thread time.
If ROS and hal-core are synchronized in time, that will be good for performance.
For example if ROS has a update time of 20ms. Then hal-core can request ros every 20ms and retrieve function values exactly
within the request time without overlapping other threads. For graphical display you need a seperate stand alone thread.
Nice !
Last edit: 26 Aug 2021 11:25 by Grotius.
- juniorfi
27 Aug 2021 07:48 #218869
by juniorfi
Hello,
Yes that was my idea days ago, to based on those components you have made there and integrate that with rtt_ros.
But I think the most tricky thing will be interact with the modules in real-time.
I'm trying to get something from the HAL documentation.
Regards
Regards
- Roiki
- Thank you received: 19
27 Aug 2021 14:28 #218910
by Roiki
Replied by Roiki on topic Drivers implementation for ROS - rtt_soem
If you want to speak from userspace to HAL you need to use DMA. So either memory buffer or atomics.
Theres hal_streamer component that does the buffered approach and atomics can be used with normal hal apis.
Though you can't get these values into the normal motion execution path of linuxcnc at present unless you want to mess with NML.
- juniorfi
31 Aug 2021 06:03 #219219
by juniorfi
Hello Roiki,
I have been reading about hal_streamer trying to find the way to implement it.
Thanks for the hint.
Right now I'm just looking to interact (Read/Write) values in real-time every time needed.
If for example one arm is moving get the real value when you ask for them and so. Same like using halcmd getp/setp.
Regards.
Regards.
Time to create page: 0.143 seconds
