EtherCAT is no longer recognized
19 Aug 2021 12:00 #218134 by Masa
EtherCAT is no longer recognized was created by Masa
Hello
If anyone knows, please let me know.
I'm trying to run a milling machine with LinuxCNC + EtherCAT. We are working while checking various settings. Yesterday, when I turned off my PC for the first time in a few days and restarted it, EtherCAT was no longer recognized. When I run "$ ethercat slaves" on the command line, it returns "Failed to obtain number of masters: Failed to open master device / dev / EtherCAT0: No such file or directory". So I confirmed the following.
Change the Ethernet port. Twice
enp2s0-> LAN enp3s0-> EtherCAT
I replaced this. I rewrote and executed EtherCAD settings and ethercat_setup_script.sh. However, the symptoms do not change.
I also replaced the Ethernet cable.
The connection is Beckhoff's EK1100 + EM7004. The EK1100 lamp no longer flashes.
By switching enp2s0 and enp3s0, the internet connection etc. will change without any problem.
Is there anything else I can look for and deal with? Or is it the only way to try reinstalling the whole thing?
thank you.
19 Aug 2021 17:47 #218165 by db1981
Replied by db1981 on topic EtherCAT is no longer recognized
please give more information about you system.
debian version, how you installed the ethercat master ( image, ec-debianize, manual)
19 Aug 2021 23:45 #218187 by Masa
Replied by Masa on topic EtherCAT is no longer recognized
db1981
Sorry for the lack of my information.
Below is the information.
masao @ LinuxCNC01: ~ $ uname -a
Linux LinuxCNC01 4.19.0-14-rt-amd64 # 1 SMP PREEMPT RT Debian 4.19.171-2 (2021-01-30) x86_64 GNU / Linux
masao @ LinuxCNC01: ~ $ linuxcnc -v
Verbose mode on
RUN_IN_PLACE = no
LINUXCNC_DIR =
LINUXCNC_BIN_DIR = / usr / bin
LINUXCNC_TCL_DIR = / usr / lib / tcltk / linuxcnc
LINUXCNC_SCRIPT_DIR =
LINUXCNC_RTLIB_DIR = / usr / lib / linuxcnc / modules
LINUXCNC_CONFIG_DIR =
LINUXCNC_LANG_DIR = / usr / lib / tcltk / linuxcnc / msgids
INIVAR = inivar
HALCMD = halcmd
LINUXCNC_EMCSH = / usr / bin / wish8.6
LINUXCNC --2.8.1
Machine configuration directory is'/home/masao/linuxcnc/configs/sim.axis-1'
Machine configuration file is'axis.ini'
INIFILE = / home / masao / linuxcnc / configs / sim.axis-1 / axis.ini
VERSION = 1.1
PARAMETER_FILE = sim.var
TASK = milltask
HALUI = halui
DISPLAY = axis
COORDINATES = X Y Z
KINEMATICS = trivkins
Starting Linux CNC ...
masao @ LinuxCNC01: ~ $ ethercat version
IgH EtherCAT master 1.5.2 unknown
The installed image is
forum.linuxcnc.org/18-computer/40328-deb...wnload-1-7-gb#196098
github.com/grotius-cnc/LINUX_RTOS/releases/tag/1.0.0
I got it from.
I got it in January 2021.
thank you.
20 Aug 2021 08:35 #218221 by db1981
Hello,
-please check if in the file " /etc/default/ethercat" the correct mac adress is set for master0_device.
-do an "sudo update-ethercat-config"
20 Aug 2021 09:09 #218225 by db1981
and please check if there exists an rules file for ethercat in /etc/udev/rules.d/
if it still not works, we will have to look in the dmesg what happens at ethercat start...
20 Aug 2021 10:52 #218229 by Masa
db1981
Thanks for your advice.
There is no problem with the MAC address. I also ran an update.
However, nothing has changed in the current situation.
I'll try to reinstall the whole thing.
Thank you very much.
20 Aug 2021 12:08 #218236 by Masa
Thank you for your additional advice.
/etc/udev/rules.d/99-ethercat.rules
Exists.
Time to create page: 0.114 seconds
