no 7i92, 7i98, 7i80 board found
25 Aug 2021 12:47 #218702 by luap
no 7i92, 7i98, 7i80 board found was created by luap
helloi am new to linuxcnc. i downloaded Linuxcnc2.08 Buster 10. I want to change all my machine from Mach to linuxcnc. But with the 7i92, 7i98 and the 7i80 on different PC's the question is the same. Wye can i not mesa flash ore open linxcnc with success. The connection to board is o.k ping is possible and works but the major function is canceled. I left the origin address 192.168.1.121 because the internet connection is different. With linuxcnc hm2_eth: Error ..... Connection refused i can not handle. The mesa flash version is the newest.
I apriciaed any answer please help to fix it
Best wishes to all and many thank fore any helpp { margin-bottom: 0.25cm; line-height: 115%; background: transparent }
25 Aug 2021 13:55 #218704 by PCW
Replied by PCW on topic no 7i92, 7i98, 7i80 board found
It sounds like your host IP address is not set properly.
For example if you set the host ip address to 192.168.1.121
you will get this behaviour.
What does the command
ip a
report?
26 Aug 2021 09:12 #218774 by luap
Replied by luap on topic no 7i92, 7i98, 7i80 board found
Thank you very much
i tested your command ip a. With Internet connection  inet shows 192.168.178.26/24 THe output from the 7i92 connection i attached in the ip.pdf
once again thank you very much fore the quick replay
26 Aug 2021 17:02 #218815 by PCW
"inet 192.168.1.121/24 brd 192.168.1.255 scope global enp1s0"
You have your host IP address set to the Mesa card address
Its needs to be different (say 192.168.1.100)
28 Aug 2021 08:25 #218966 by luap
Hello
thank you very much.
The Internet host addr is 192.168.178.26.
the Mesacard addr is       192.168.1.121. Why i set the host addr to the Mesacard. That i do not understand. The host addr i can not change in The Wicd Network manager, just the Mesacard addr. I already changed the Mesacard addr to 10.10.10.10 the same: No 7i90,7i98,7i80 board found I put a new Ping and ip a answer in the attachment please have a look to it.
Thank you a lot i hope finaly i may understand what you say
28 Aug 2021 08:29 #218968 by luap
Here now the attachment
28 Aug 2021 13:51 - 28 Aug 2021 13:54 #219002 by PCW
The host address for enp1s0 is 192.168.1.121
so when you ping 192.168.1.121 you are pinging yourself:
2: enp1s0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc pfifo_fast state UP
group default qlen 1000
link/ether 38:d5:47:16:f9:a3 brd ff:ff:ff:ff:ff:ff
valid_lft forever preferred_lft forever
inet6 fe80::3ad5:47ff:fe16:f9a3/64 scope link
Last edit: 28 Aug 2021 13:54 by PCW.
29 Aug 2021 09:42 #219080 by luap
Dear PCW thank you very much fore your answer.
now i come bit nearer what you say. The host addr is the one to the Ethernet and the 7i92 addr is set to the adaquat addr.
Please consider i have just one Ethernt RJ45 connector on th ASUS AM1M-A. So i can connect just the Ethernet ore the 7i92 not both at the same time. If you have a working Mesa Board with Ethernet is it possible to put it in the attachment so i may see the differenc and how many RJ45 connector on the board.
In the new attachment i changed the 7i92 addr to 10.10.10.10 netmask to 255.0.0.0.
Thank a lot fore your help
29 Aug 2021 14:35 #219109 by PCW
In any case, the host address must _not_ be the same as the Mesa card address
Here is an example for a Mesa card at 10.10.10.10
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000
    link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
    inet 127.0.0.1/8 scope host lo
    inet6 ::1/128 scope host
2: eno1: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc fq_codel state UP group default qlen 1000
    link/ether ec:b1:d7:6c:a2:da brd ff:ff:ff:ff:ff:ff
    inet 10.10.10.100/24 brd 10.10.10.255 scope global eno1
3: wlx74da388d8d1c: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc mq state UP group default qlen 1000
Also if you need an internet connection, it best to add a USB-Ethernet or USB-WIFI dongle for the
internet connection, leaving the motherboard Ethernet for LinuxCNC.
31 Aug 2021 13:04 #219242 by luap
Dear PCW
yes i see your ip a looks in 2. State quit different. Believe the netmask is set to 255.0.0.0 i do not no why there is in my ip a 255.255.255.255 that is not true. I do not no what make it. I guess there is something with the Buster 10. A couple month earlier i can make sudo apt-get install task-xfce-desktop and the 7i98 worked but when i installed Busterlinuxcnc new it is not longer possible. Some thing strange happened than this time. Nothing works straight away. It is not an Linuxcnc problem it comes from the debian side. I Installed first debian 10 Mate. Than i wanted to install linuxcnc but after dozends off debendians where installed the last one is not longer available it where fore debian wheezy. So i reinstalled Debian Buster Linuxcnc and there i am now. Is there some changes made in debian Buster Linuxcnc i will load it new and install it new.
Thank you a lot fore youre  great help.
