no 7i92, 7i98, 7i80 board found
- Online
- Thank you received: 5274
31 Aug 2021 13:57 - 31 Aug 2021 14:00 #219247
Replied by PCW on topic no 7i92, 7i98, 7i80 board found
The issue is not the Linux version, but that you have set you host interface
IP address to the wrong value. It cannot be set to the same address as the
Ethernet FPGA card. This is something setup by hand with net manager or
editing the interfaces file (see the hm2_eth manual page: man hm2_eth)
If the FPGA card is set for 192.168.1.121, I would suggest setting the host
IP address to 192.168.1.100/24. If the FPGA card is set for 10.10.10.10, I would
suggest setting the host IP address to 10.10.10.100/24
Last edit: 31 Aug 2021 14:00 by PCW.
- Thank you received: 7420
31 Aug 2021 17:50 #219267
Replied by tommylight on topic no 7i92, 7i98, 7i80 board found
host = PC = computer
Pretty sure he is using google to translate ...
