✅ (Solved) LinuxCNC + EtherCAT
- juniorfi
- Thank you received: 4
27 Aug 2021 07:52 - 08 Oct 2021 09:22 #218870
by juniorfi
✅ (Solved) LinuxCNC + EtherCAT was created by juniorfi
Hello,
I have read that due LinuxCNC and EtherCAT licenses there is not possible to build a LinuxCNC with EtherCAT drivers and master.
Could I ask why? if the code is GPLv2?
Or maybe because of this?:NoticeThe license above concerns the source code only. Using the EtherCAT technology and brand is only permitted in compliance with the industrial property and similar rights of Beckhoff Automation GmbH.
Source: etherlab.org/en/ethercat/
Regards.
Regards.
Last edit: 08 Oct 2021 09:22 by juniorfi.
- Thank you received: 4654
31 Aug 2021 13:25 #219244
Replied by andypugh on topic LinuxCNC + EtherCAT
Yes, the issue is with the Beckhoff licensing.
And, to an extent, with the LinuxCNC team not being lawyers and feeling that it is best to proceed with caution in an unclear situation like this.
The following user(s) said Thank You: juniorfi
- juniorfi
02 Sep 2021 07:21 #219410
by juniorfi
Replied by juniorfi on topic LinuxCNC + EtherCAT
Thanks for the clarification.
Time to create page: 0.098 seconds
