- Thank you received: 5
Ethercat - newbie guidelines
- 3radfahrer
4 years 9 months ago - 4 years 9 months ago #230799
by 3radfahrer
Replied by 3radfahrer on topic Ethercat - newbie guidelines
Hello Hakan,
nice video
regarding the cia402 (I unfortunately don't have one): in order to get the Amps in OP-Mode and switch the drives on, do you have to handle the statemachine manually in the hal-files, or is this all handled by the driver you installed?
edit: of course are my amps also cia402 conform. I oriented for the implementation on the beckhoff-description and skipped this part in the documentation
nice video
Last edit: 4 years 9 months ago by 3radfahrer.
- Thank you received: 4153
4 years 9 months ago #230806
There are some requirements in your hal file regarding component load order.
Replied by rodw on topic Ethercat - newbie guidelines
Yes, turning on and changing to home states is all handled for you with cia402 drives by the component.Hello Hakan,
nice video
The following user(s) said Thank You: 3radfahrer
- Grotius
- Thank you received: 2349
4 years 9 months ago - 4 years 9 months ago #230826
by Grotius
Replied by Grotius on topic Ethercat - newbie guidelines
For info. The ethercat iso downloads following the link of Padstar:
637 github.
174 sourceforge.
637 github.
174 sourceforge.
Last edit: 4 years 9 months ago by Grotius.
- 3radfahrer
4 years 9 months ago #231049
by 3radfahrer
Thanks for this info.
Then it seems to be quite similar to the implementation of my amps in combination with the generic driver
The following user(s) said Thank You: tiagounderground
4 years 9 months ago #231079
Can you share your config? I did quite a bit of rework on the cia402.comp component and can now get my drives to home and rehome consistently but if left to travel too far, I get following errors. I am not sure why because we are setting the pos-fb = pos-cmd in the component while homing so there should not be anything to complain about.Thanks for this info.
Then it seems to be quite similar to the implementation of my amps in combination with the generic driver![]()
- db1981
- Thank you received: 276
4 years 9 months ago #231129
by db1981
Replied by db1981 on topic Ethercat - newbie guidelines
strange,
check the following error from the joint with halscope while homing, it should be every time zero.
if not , add modes_of_operation and the home bit to check if something happens during homing.
Time to create page: 0.239 seconds
