✅ (Solved) EL6900 | User and password
  • juniorfi
  • juniorfi's Avatar Topic Author
  • Senior Member
  • Senior Member
17 Sep 2021 08:57 - 08 Oct 2021 09:20 #220866 by juniorfi
✅ (Solved) EL6900 | User and password was created by juniorfi
Hello,
Does someone have tried the EL6900 before?
Do we need to put the user and password as default one to interact with that terminal?
Could we use our own user/password?
I'm still trying to get TwinSAFE working and I'm looking forward to get something working to create some documentation for future people that would like to use/contribute to the project.
Regards
Last edit: 08 Oct 2021 09:20 by juniorfi.
18 Sep 2021 00:15 #220964 by db1981
Replied by db1981 on topic EL6900 | Use and password
Hello,
you have to setup and configure the card in Twincat and to download the safty project with twincat to the card. This could not be done with lcnc / Etherlab Master.
For the later use in Linuxcnc the configured EL6900 is a "black box" with only the defined Twinsafegroup IN and Outputs. The downloaded and enabled safty project handels its functionality then stand alone ....
default:
user : Administrator
pass : TwinSAFE
In Twincat you can define your one user / password.
The following user(s) said Thank You: juniorfi
Time to create page: 0.096 seconds
