Ethercat retrofit question
- Niko
- Thank you received: 5
12 Dec 2021 12:07 #228913
by Niko
Replied by Niko on topic Ethercat retrofit question
Does anybody here have an active membership in ethercat.org ?
I'd like to contact the manufacturer of my drive . It's been months since I sent them an email and still nothing . My hope is to find someone knowledgable in these drives on their side .
- Niko
21 Dec 2021 18:08 #229638
by Niko
OK, major success today . With the aid of siitool, hex editor and the bin from one of the other drives I managed to cobble together a valid bin file and flash the spindle drive with it .
All that's left is to initialise the control panel .
- Niko
13 Mar 2022 15:58 #237122
by Niko
With the spindle running, all that's left is to find a good way to home it before tool-changing and figuring out the DC parameters to smooth out motion .
How is spindle homing usually handled in ethercat drives ?
I see no index pulse, and every time it's powered up it counts from a relative position .
Cheers
Cheers
- Niko
19 Mar 2022 13:43 - 19 Mar 2022 14:03 #237715
by Niko
So the machine works mostly nice . But sometimes it gets really noisy . Must be something related to DC sync . Here are my settings :
<master idx="0" appTimePeriod="1000000" refClockSyncCycles="100">
slaves 2-6
<dcConf assignActivate="300" sync0Cycle="*1" sync0Shift="0"/>
The function of refClockSyncCycles and appTimePeriod is clear . But what do the parameters in the slave section do ?
Also, sometimes it just leaves OP state while the machine is idle, and dmesg records PLL errors .
Edit : that noise is seen as spikes in f-error .
slaves 2-6
Last edit: 19 Mar 2022 14:03 by Niko.
- db1981
- Thank you received: 276
20 Mar 2022 09:21 #237782
by db1981
Replied by db1981 on topic Ethercat retrofit question
this pll errors are often related to jitter on the main_thread or by the network card.
Are you using the generic etherlab driver for the network card, in the past i had mostly troubles with rt8169 chip.
One way to solve this, could be to clock the lcnc task to the ethercat devices.
This could be done by setting refClockSyncCycles to "-1" but for this you would have to use the lcnc master version, or you would have to install an patch to an RIP 2.8 Version.
Search in the forum for "add-task-pll-functions", i have described this a few times.
The following user(s) said Thank You: Niko
- Niko
27 Mar 2022 09:09 #238443
by Niko
So this PLL patch is installed in the lcec_ec_master in you repo right ?
Also found the "add-task-pll-functions" in sittner's linuxcnc-ethercat repo .
Is that patch used for the kernel or the driver ?
- db1981
27 Mar 2022 09:45 #238446
by db1981
no, the lcec_ec_master in my repo is only an deb file with the ethercat master + special functions eoe, sii overwrite etc...
the patch in sittner linuxcnc-ethercat repo is the right one.
this patch has to be applied to linuxcnc/src and then linuxcnc has to be compiled again.
This patchs makes changes to the rtapi part of linuxcnc.
If you use 2.9 (master) then the patch is already in linuxcnc...
- Niko
27 Mar 2022 10:42 #238449
by Niko
OK . I taught the kernel needed recompiling .
So it's just a case of building 2.9 from git .
- Niko
03 Apr 2022 16:03 - 03 Apr 2022 16:03 #239187
by Niko
So I upgraded to 2.9 but the pll errors persist .
I also checked the ethernet controller and it's an intel i211 .
Is there a more appropriate driver for this ? Currently I'm running the generic one .
Also can I test jitter while the CNC is running and how can it be minimised ?
Last edit: 03 Apr 2022 16:03 by Niko.
- db1981
03 Apr 2022 16:06 #239188
by db1981
did you change refClockSyncCycles in the ethercat-conf.xml to "-1" ?
Time to create page: 0.197 seconds
