Ethercat retrofit question
- db1981
- Thank you received: 276
20 Mar 2022 09:21 #237782
by db1981
Replied by db1981 on topic Ethercat retrofit question
this pll errors are often related to jitter on the main_thread or by the network card.
Are you using the generic etherlab driver for the network card, in the past i had mostly troubles with rt8169 chip.
One way to solve this, could be to clock the lcnc task to the ethercat devices.
This could be done by setting refClockSyncCycles to "-1" but for this you would have to use the lcnc master version, or you would have to install an patch to an RIP 2.8 Version.
Search in the forum for "add-task-pll-functions", i have described this a few times.
The following user(s) said Thank You: Niko
- Niko
- Thank you received: 5
27 Mar 2022 09:09 #238443
by Niko
Replied by Niko on topic Ethercat retrofit question
So this PLL patch is installed in the lcec_ec_master in you repo right ?
Also found the "add-task-pll-functions" in sittner's linuxcnc-ethercat repo .
Is that patch used for the kernel or the driver ?
- db1981
27 Mar 2022 09:45 #238446
by db1981
no, the lcec_ec_master in my repo is only an deb file with the ethercat master + special functions eoe, sii overwrite etc...
the patch in sittner linuxcnc-ethercat repo is the right one.
this patch has to be applied to linuxcnc/src and then linuxcnc has to be compiled again.
This patchs makes changes to the rtapi part of linuxcnc.
If you use 2.9 (master) then the patch is already in linuxcnc...
- Niko
27 Mar 2022 10:42 #238449
by Niko
OK . I taught the kernel needed recompiling .
So it's just a case of building 2.9 from git .
- Niko
03 Apr 2022 16:03 - 03 Apr 2022 16:03 #239187
by Niko
So I upgraded to 2.9 but the pll errors persist .
I also checked the ethernet controller and it's an intel i211 .
Is there a more appropriate driver for this ? Currently I'm running the generic one .
Also can I test jitter while the CNC is running and how can it be minimised ?
Last edit: 03 Apr 2022 16:03 by Niko.
- db1981
03 Apr 2022 16:06 #239188
by db1981
did you change refClockSyncCycles in the ethercat-conf.xml to "-1" ?
- Thank you received: 4138
03 Apr 2022 18:30 #239198
linuxcnc.org/docs/devel/html/man/man9/hm...FACE%20CONFIGURATION
Replied by rodw on topic Ethercat retrofit question
I wonder if the Intel NIC might benefit from the irq_coalescence settings that are suggested for Mesa configs?So I upgraded to 2.9 but the pll errors persist .
- Niko
03 Apr 2022 18:55 - 03 Apr 2022 18:58 #239201
by Niko
Yes, I changed that .
Should I change anything else in the slave setup lines ?
Edit :
I'll do that as well, Rod .
Edit :
Last edit: 03 Apr 2022 18:58 by Niko.
- db1981
03 Apr 2022 19:59 #239209
by db1981
to get shure that there exist no hardware / Nic errors.
Check with the command "ethercat master" for lost frames.
There should be no changes in the values while linuxcnc is running and your pll problem occurs.
- Niko
17 Apr 2022 08:55 - 17 Apr 2022 09:37 #240447
by Niko
OK, so the problem it obvious now . It takes slave 0 clock for reference . Should be slave 1.
Here's the output :
Which is odd as the first slave doesn't have a dcConf line .
Lost frames stays at 22 .Those syncShift values are selected with this command :Is there anything wrong with this, and why is it selecting slave 0 for reference ?
Output of dmesg :
Here's the output :
Master0
Phase: Operation
Active: yes
Slaves: 7
Ethernet devices:
Main: 00:13:95:1c:cc:68 (attached)
Link: UP
Tx frames: 2310920
Tx bytes: 780785312
Rx frames: 2310919
Rx bytes: 780784976
Tx errors: 0
Tx frame rate [1/s]: 1000 1000 999
Tx rate [KByte/s]: 329.7 329.7 329.2
Rx frame rate [1/s]: 1000 1000 999
Rx rate [KByte/s]: 329.7 329.7 329.2
Common:
Tx frames: 2332606
Tx bytes: 784265664
Rx frames: 2332584
Rx bytes: 784259604
Lost frames: 22
Loss rate [1/s]: 0 0 0
Frame loss [%]: 0.0 0.0 0.0
Distributed clocks:
Reference clock: Slave 0
DC reference time: 703502574227961000
Application time: 703502906860973789
2022-04-17 09:28:26.860973789Which is odd as the first slave doesn't have a dcConf line .
<masters>
<master idx="0" appTimePeriod="1000000" refClockSyncCycles="-1">
<slave idx="0" type="generic" vid="50414e43" pid="00087611" configPdos="false">
<syncManager idx="2" dir="out">
</syncManager>
<syncManager idx="3" dir="in">
</syncManager>
</slave>
<slave idx="1" type="generic" vid="000002E1" pid="00000000" configPdos="true">
<dcConf assignActivate="300" sync0Cycle="*1" sync0Shift="660"/>
</syncManager>
</syncManager>
</slave>
<slave idx="2" type="generic" vid="000002E1" pid="00000000" configPdos="false">
<dcConf assignActivate="300" sync0Cycle="*1" sync0Shift="1359"/>
</syncManager>
</syncManager>
</slave>
<slave idx="3" type="generic" vid="000002E1" pid="00000000" configPdos="false">
<dcConf assignActivate="300" sync0Cycle="*1" sync0Shift="2079"/>
</syncManager>
</syncManager>
</slave>
<slave idx="4" type="generic" vid="000002E1" pid="00000000" configPdos="false">
<dcConf assignActivate="300" sync0Cycle="*1" sync0Shift="2779"/>
</syncManager>
</syncManager>
</slave>
<slave idx="5" type="generic" vid="000002E1" pid="00000000" configPdos="false">
<dcConf assignActivate="300" sync0Cycle="*1" sync0Shift="3499"/>
</syncManager>
</syncManager>
</slave>
<slave idx="6" type="generic" vid="000005be" pid="00000001" configPdos="true">
<dcConf assignActivate="300" sync0Cycle="*1" sync0Shift="4139"/>
</syncManager>
</syncManager>
</slave>
</master>
</masters>ethercat graph DC | dot -Tsvg > bus.svgOutput of dmesg :
Last edit: 17 Apr 2022 09:37 by Niko.
Time to create page: 0.164 seconds
