Delta comunication issue
- 0x2102
- Thank you received: 88
11 Nov 2021 22:51 #226157
by 0x2102
Replied by 0x2102 on topic Delta comunication issue
Hello fehim,
would you mind sharing your final working configuration?
Thanks.
Thanks.
- fehim
15 Nov 2021 12:20 #226572
by fehim
Replied by fehim on topic Delta comunication issue
Hello all,
This problem still there. I was misunderstood that the problem is gone when I set the deasda xml file. Velocity controlling is not a solution. Sorry for all for the wrong alarm. If someone can help about this issue I also appreciated.
- fehim
19 Nov 2021 14:25 #226985
by fehim
SOLVED!
Hello all,
change teh servo parameter communication freq to 1mbps and change in the xml file apptime period to 1. Than all should work
Hello all,
The following user(s) said Thank You: uur.ersan, mehdidadash
- papagno-source
- Thank you received: 13
20 Mar 2022 09:35 #237784
by papagno-source
Replied by papagno-source on topic Delta comunication issue
HI fehim.
I have use the your xml file posted before, the motor move, but rarely have vibration and it stop after some second himself.
I don't understand what is parameter in drive and apptime period .
please can help
please can help
- fehim
15 May 2022 10:34 #243010
by fehim
these are delta?
- mehdidadash
- Thank you received: 4
10 Dec 2022 09:03 #259067
by mehdidadash
Replied by mehdidadash on topic Delta comunication issue
Hi fehim.
would you share your xml, hal and ini files with us ?
Time to create page: 1.080 seconds
