end topic.
4 years 10 months ago - 4 years 9 months ago #229240
by huhuoyun
end topic. was created by huhuoyun
The experimental environment is linuxcnc2.8.2, and the IGH Ethercat driver and linuxcnc-ethercat real-time library are installed; the hardware selection uses Inovance servo motors and Panasonic servo motors. The detailed models are SV660NS5R5I and Panasonic A6B. INI file reference:
paste.in/jqz3nV
, HAL file reference:
paste.in/ft6kUz
, XML file reference:
paste.in/pLlJ7z
; The hardware is connected to the X2A servo drive and a single servo motor through a network cable. Panasonic Servo still fails to be driven under Linuxcnc-2.8.2, and other solutions are available online.
<blockquote class="twitter-tweet"><p lang="und" dir="ltr"><a href=" t.co/Kb7aZcQ8fu ">pic.twitter.com/Kb7aZcQ8fu</a></p>— huhuoyun (@huhuoyun) <a href=" twitter.com/huhuoyun/status/147165760385...?ref_src=twsrc%5Etfw ">December 17, 2021</a></blockquote> <script async src=" platform.twitter.com/widgets.js " charset="utf-8"></script>
Last edit: 4 years 9 months ago by huhuoyun.
4 years 10 months ago #229244
by huhuoyun
Replied by huhuoyun on topic LinuxCNC drive motor failed, online and other solutions.
The servo motor has been stuck in the PREOP state, I don't know why...
4 years 10 months ago - 4 years 10 months ago #229245
by huhuoyun
The motor is successfully driven by the following procedure. After each interruption of execution, the motor alarm must be manually cleared before the motor can be rotated again.
gcc t1.c -o t1 -I /works/ethercat/include/ -lethercat
#include <errno.h>
#include <signal.h>
#include <stdio.h>
#include <string.h>
#include <sys/resource.h>
#include <sys/time.h>
#include <sys/types.h>
#include <unistd.h>
#include <sys/mman.h>
#include "ecrt.h"
/*Application Parameters*/
#define TASK_FREQUENCY 100 /*Hz*/
#define TIMOUT_CLEAR_ERROR (1*TASK_FREQUENCY) /*clearing error timeout*/
#define TARGET_VELOCITY 8388608 /*target velocity*/
#define PROFILE_VELOCITY 3 /*Operation mode for 0x6060:0*/
/*EtherCAT*/
static ec_master_t *master = NULL;
static ec_master_state_t master_state = {};
static ec_domain_t *domain1 = NULL;
static ec_domain_state_t domain1_state = {};
static ec_slave_config_t *sc_A6B;
static ec_slave_config_state_t sc_A6B_state = {};
/*Process Data*/
static uint8_t *domain1_pd = NULL;
#define A6BSlavePos 0,0 /*EtherCAT address on the bus*/
#define Panasonic 0x0000066F,0x60380006 /*Vendor ID, product code*/
/*Offsets for PDO entries*/
static struct{
unsigned int operation_mode;
unsigned int ctrl_word;
unsigned int target_velocity;
unsigned int status_word;
unsigned int mode_display;
unsigned int current_velocity;
// signed int current_velocity;
}offset;
const static ec_pdo_entry_reg_t domain1_regs = {
{A6BSlavePos, Panasonic, 0x6040, 0, &offset.ctrl_word},
{A6BSlavePos, Panasonic, 0x6060, 0, &offset.operation_mode },
{A6BSlavePos, Panasonic, 0x60FF, 0, &offset.target_velocity},
{A6BSlavePos, Panasonic, 0x6041, 0, &offset.status_word},
{A6BSlavePos, Panasonic, 0x6061, 0, &offset.mode_display},
{A6BSlavePos, Panasonic, 0x606C, 0, &offset.current_velocity},
static unsigned int counter = 0;
//static int state = -500;
/*Config PDOs*/
static ec_pdo_entry_info_t A6B_pdo_entries = {
/*RxPdo 0x1600*/
{0x6040, 0x00, 16},
{0x6060, 0x00, 8 },
{0x60FF, 0x00, 32},
/*TxPdo 0x1A00*/
{0x6041, 0x00, 16},
{0x6061, 0x00, 8},
{0x606C, 0x00, 32}
static ec_pdo_info_t A6B_pdos = {
//RxPdo
{0x1600, 3, A6B_pdo_entries + 0 },
//TxPdo
{0x1A00, 3, A6B_pdo_entries + 3 }
static ec_sync_info_t A6B_syncs = {
{ 0, EC_DIR_OUTPUT, 0, NULL, EC_WD_DISABLE },
{ 1, EC_DIR_INPUT, 0, NULL, EC_WD_DISABLE },
{ 2, EC_DIR_OUTPUT, 1, A6B_pdos + 0, EC_WD_DISABLE },
{ 3, EC_DIR_INPUT, 1, A6B_pdos + 1, EC_WD_DISABLE },
{ 0xFF}
void check_domain1_state(void)
ec_domain_state_t ds;
ecrt_domain_state(domain1, &ds);
if (ds.working_counter != domain1_state.working_counter)
printf("Domain1: WC %u.\n", ds.working_counter);
if (ds.wc_state != domain1_state.wc_state)
printf("Domain1: State %u.\n", ds.wc_state);
domain1_state = ds;
void check_master_state(void)
ec_master_state_t ms;
ecrt_master_state(master, &ms);
if (ms.slaves_responding != master_state.slaves_responding)
printf("%u slave(s).\n", ms.slaves_responding);
if (ms.al_states != master_state.al_states)
printf("AL states: 0x%02X.\n", ms.al_states);
if (ms.link_up != master_state.link_up)
printf("Link is %s.\n", ms.link_up ? "up" : "down");
master_state = ms;
void check_slave_config_states(void)
ec_slave_config_state_t s;
ecrt_slave_config_state(sc_A6B, &s);
if (s.al_state != sc_A6B_state.al_state)
printf("A6B: State 0x%02X.\n", s.al_state);
if (s.online != sc_A6B_state.online)
printf("A6B: %s.\n", s.online ? "online" : "offline");
if (s.operational != sc_A6B_state.operational)
printf("A6B: %soperational.\n", s.operational ? "" : "Not ");
sc_A6B_state = s;
void cyclic_task()
static unsigned int timeout_error = 0;
static uint16_t command=0x004F;
static int32_t target_velocity = TARGET_VELOCITY;
uint16_t status;
int8_t opmode;
int32_t current_velocity;
// int32_t command_value;
/*Receive process data*/
ecrt_master_receive(master);
ecrt_domain_process(domain1);
/*Check process data state(optional)*/
check_domain1_state();
counter = TASK_FREQUENCY;
//Check for master state
check_master_state();
//Check for slave configuration state(s)
check_slave_config_states();
/*Read inputs*/
status = EC_READ_U16(domain1_pd + offset.status_word);
opmode = EC_READ_U8(domain1_pd + offset.mode_display);
current_velocity = EC_READ_S32(domain1_pd + offset.current_velocity);
printf("A6B: act velocity = %d , cmd = 0x%x , status = 0x%x , opmode = 0x%x\n",
(current_velocity*60)/target_velocity, command, status, opmode);
//DS402 CANOpen over EtherCAT status machine
if( (status & command) == 0x0040 )
EC_WRITE_U16(domain1_pd + offset.ctrl_word, 0x0006 );
EC_WRITE_S8(domain1_pd + offset.operation_mode, PROFILE_VELOCITY);
command = 0x006F;
else if( (status & command) == 0x0021)
EC_WRITE_U16(domain1_pd + offset.ctrl_word, 0x0007 );
command = 0x006F;
else if( (status & command) == 0x0023)
EC_WRITE_U16(domain1_pd + offset.ctrl_word, 0x000f );
EC_WRITE_S32(domain1_pd + offset.target_velocity, target_velocity);
command = 0x006F;
//operation enabled
else if( (status & command) == 0x0027)
EC_WRITE_U16(domain1_pd + offset.ctrl_word, 0x001f);
/*Send process data*/
ecrt_domain_queue(domain1);
ecrt_master_send(master);
int main(int argc, char **argv)
master = ecrt_request_master(0);
if (!master)
exit(EXIT_FAILURE);
domain1 = ecrt_master_create_domain(master);
if (!domain1)
exit(EXIT_FAILURE);
if (!(sc_A6B = ecrt_master_slave_config(master, A6BSlavePos, Panasonic)))
fprintf(stderr, "Failed to get slave configuration for A6B!\n");
exit(EXIT_FAILURE);
// printf("alias=%d,vid=%d,watchdog_divider=%d",sc_A6B->alias,sc_A6B->position,sc_A6B->watchdog_divider);
printf("Configuring PDOs...\n");
if (ecrt_slave_config_pdos(sc_A6B, EC_END, A6B_syncs))
fprintf(stderr, "Failed to configure A6B PDOs!\n");
exit(EXIT_FAILURE);
else
printf("*Success to configuring A6B PDOs*\n");
if (ecrt_domain_reg_pdo_entry_list(domain1, domain1_regs))
fprintf(stderr, "PDO entry registration failed!\n");
exit(EXIT_FAILURE);
else
printf("*Success to configuring A6B PDO entry*\n");
printf("operation_mode=%d, ctrl_word=%d, target_velocity=%d, status_word=%d, mode_display=%d, current_velocity=%d\n",offset.operation_mode,offset.ctrl_word,offset.target_velocity,offset.status_word,offset.mode_display,offset.current_velocity);
printf("Activating master...\n");
if (ecrt_master_activate(master)) {
exit(EXIT_FAILURE);
else
printf("*Master activated*\n");
if (!(domain1_pd = ecrt_domain_data(domain1))) {
exit(EXIT_FAILURE);
printf("*It's working now*\n");
while (1)
usleep(100000/TASK_FREQUENCY);
cyclic_task();
ecrt_master_deactive(master);
return EXIT_SUCCESS;
#include <errno.h>
#include <signal.h>
#include <stdio.h>
#include <string.h>
#include <unistd.h>
#include "ecrt.h"
/*EtherCAT*/
/*Process Data*/
static struct{
}offset;
/*Config PDOs*/
/*RxPdo 0x1600*/
{0x6040, 0x00, 16},
{0x6060, 0x00, 8 },
{0x60FF, 0x00, 32},
/*TxPdo 0x1A00*/
{0x6041, 0x00, 16},
{0x6061, 0x00, 8},
{0x606C, 0x00, 32}
//RxPdo
//TxPdo
{ 0xFF}
domain1_state = ds;
master_state = ms;
sc_A6B_state = s;
void cyclic_task()
uint16_t status;
int8_t opmode;
/*Read inputs*/
command = 0x006F;
command = 0x006F;
command = 0x006F;
//operation enabled
if (!master)
exit(EXIT_FAILURE);
if (!domain1)
exit(EXIT_FAILURE);
exit(EXIT_FAILURE);
exit(EXIT_FAILURE);
else
exit(EXIT_FAILURE);
else
exit(EXIT_FAILURE);
else
exit(EXIT_FAILURE);
while (1)
cyclic_task();
Last edit: 4 years 10 months ago by huhuoyun.
4 years 10 months ago #229247
by huhuoyun
The above program is like this before running
root@x:/mnt/root# ethercat slaves
0 0:0 PREOP + MBDLN25BE
After the above program runs, it looks like this
root@x:~# ethercat slaves
0 0:0 OP + MBDLN25BE
4 years 10 months ago - 4 years 10 months ago #229249
by huhuoyun
The running video is as follows:
<blockquote class="twitter-tweet"><p lang="und" dir="ltr"><a href=" t.co/kWnUfFBT1X ">pic.twitter.com/kWnUfFBT1X</a></p>— huhuoyun (@huhuoyun) <a href=" twitter.com/huhuoyun/status/147166375081...?ref_src=twsrc%5Etfw ">December 17, 2021</a></blockquote> <script async src=" platform.twitter.com/widgets.js " charset="utf-8"></script>
- marq_torque
- Thank you received: 3
3 years 1 month ago #281808
by marq_torque
Replied by marq_torque on topic LinuxCNC drive motor failed, online and other solutions.
Hey huhuoyun,
I tried to download ini hal and xml files for A6B, links are broken. Can you upload it again or attach here in reply?
Time to create page: 0.072 seconds
