EL5101 encoder interface
- papagno-source
- Thank you received: 13
08 Apr 2022 18:06 #239683
by papagno-source
EL5101 encoder interface was created by papagno-source
Hi at all.
I wanted to ask if anyone has ever tried to use an el5101 encoder card to do spindle orientation and read the position value. In the documentation I read that there is a PDO where to read the position, but I did not understand how to reset the counter when the zero mark of the encoder is hit. Can you help me ?
- db1981
- Thank you received: 276
08 Apr 2022 19:03 #239688
by db1981
Replied by db1981 on topic EL5101 encoder interface
this is handled like homing on index.
for sensor on the external latch input
set the "enc-index-ext-pos-enable" or "enc-index-ext-neg-enable" pin
for sensor on the C Line from the encoder
set the "enc-index-c-enable" pin
if the zero event ocoured the card sets its internal counter to zero or to the pos
you told with the set_raw_count_val pin and clears the enc-index-xxx pin.
- papagno-source
08 Apr 2022 19:11 #239689
by papagno-source
Replied by papagno-source on topic EL5101 encoder interface
Thanks for support.
please have the xml file for pdo config example for el5101 ?
More thanks
More thanks
- db1981
08 Apr 2022 19:14 #239690
by db1981
i am talking about the native el5101 driver.
Module name is "EL5101"
- papagno-source
08 Apr 2022 19:24 #239691
by papagno-source
Ok thanks, about scaling the position value , use some component or another pin the el5101 driver ?
Exist some hal example for pin connection ?
Again more thanks
Again more thanks
- db1981
08 Apr 2022 19:30 #239693
by db1981
enc-pos-scale is the scale pin. (increment per machine unit)
github.com/sittner/linuxcnc-ethercat/blo...er/src/lcec_el5101.c
there all pins are listed. line 75-95
- papagno-source
08 Apr 2022 19:34 #239694
by papagno-source
OK thanks for help and good day.
- Sakhalin_Cat
- Thank you received: 7
19 Mar 2024 10:18 #296300
by Sakhalin_Cat
Replied by Sakhalin_Cat on topic EL5101 encoder interface
Hello.
I use module EL5101 in my system. I have a suspicion that the module has programmed parameters inside that are different from the default ones. I read here on the forum a way to reset this module to factory settings using the SDO/PDO commands, but I can’t find this message.
Please tell me a method to reset this module.
- scottlaird
- Thank you received: 161
20 Mar 2024 18:30 #296405
by scottlaird
Replied by scottlaird on topic EL5101 encoder interface
Generally, Beckhoff lists this in their docs, which you can get to via beckhoff.com/EL5101 -> documentation. For the EL5101, this covered on download.beckhoff.com/download/Document/...l5101en.pdf#page=273. You *should* be able to factory reset it via `ethercat download -p XX 0x1011 1 1684107116`, where XX is your EL5101's slave ID.
Having said that, using TwinCat on Windows to reset things tends to work better than using `ethercat` on the command line.
Time to create page: 0.360 seconds
