EL5101 encoder interface
4 years 6 months ago #239683 by papagno-source
Hi at all.
I wanted to ask if anyone has ever tried to use an el5101 encoder card to do spindle orientation and read the position value. In the documentation I read that there is a PDO where to read the position, but I did not understand how to reset the counter when the zero mark of the encoder is hit. Can you help me ?
4 years 6 months ago #239688 by db1981
Replied by db1981 on topic EL5101 encoder interface
this is handled like homing on index.
for sensor on the external latch input
set the "enc-index-ext-pos-enable" or "enc-index-ext-neg-enable" pin
for sensor on the C Line from the encoder
set the "enc-index-c-enable" pin
if the zero event ocoured the card sets its internal counter to zero or to the pos
you told with the set_raw_count_val pin and clears the enc-index-xxx pin.
4 years 6 months ago #239689 by papagno-source
Thanks for support.
please have the xml file for pdo config example for el5101 ?
More thanks
4 years 6 months ago #239690 by db1981
i am talking about the native el5101 driver.
Module name is "EL5101"
4 years 6 months ago #239691 by papagno-source
Ok thanks, about scaling the position value , use some component or another pin the el5101 driver ?
Exist some hal example for pin connection ?
Again more thanks
4 years 6 months ago #239693 by db1981
enc-pos-scale is the scale pin. (increment per machine unit)
github.com/sittner/linuxcnc-ethercat/blo...er/src/lcec_el5101.c
there all pins are listed. line 75-95
