I have alread used 2khz or 4khz servo-threads.
The limit depends on your pc, if it can produce this task speeds without bit latency / jitter.
do a check with the latency-test tool.
don't forget to match the apptimeperiod value in the ethercat-conf.xml with the new value for servo_period...
