Change standart Name of Beckhoff models
  • TheRoslyak
  • TheRoslyak's Avatar Topic Author
  • Elite Member
  • Elite Member
26 May 2022 10:06 #243902 by TheRoslyak
Change standart Name of Beckhoff models was created by TheRoslyak
Hi everyone.
Tell me if it is possible to set standard Beckhoff modules (like EL2008),own names. Better in xml because it is first layer then hal-layer.
I need address to several hundred pins. And if it have name lcec.0.D2.dout-0 ("D.OUT.1") or lcec.0.D3.dout-0 ("D.OUT.9") and etc
I know that I can set signal name in Hal. But better that I will describe in xml
26 May 2022 15:48 #243945 by db1981
Replied by db1981 on topic Change standart Name of Beckhoff models
if you want to set names for single pins from precoded Modules, this is not possible.
This would need changes in the source from the Beckhoff Module Drivers and lcec_conf.
07 Jun 2022 04:01 #244713 by Rios
Replied by Rios on topic Change standart Name of Beckhoff models
This is also a question that i have , if we cant change the name directly in the lcec pins , how can we at least change/link for example the "lcec.0.C1_IN_1.din-0" to any named variable ?
07 Jun 2022 04:25 #244715 by db1981
this has to be done in hal.
"net water-sensor <= lcec.0.C1_IN_1.din-0" links your lcec pin to the net "water-sensor" after this you can use "water-sensor" in your hal.
"net water-coil => lcec.0.dout-xxx"
"net water-sensor => water-coil"
