- Thank you received: 276
"gaps" with 0x000 x00
- db1981
4 years 5 months ago #244153
by db1981
Replied by db1981 on topic "gaps" with 0x000 x00
if you install etherlab with ec-debianize, there will be applied some patches from sittner and an bigger patchset from gavin lambert.
But ec-debianize is a bit outdated. I have not installed debian 11 yet, so i did not need to create an ethercat deb11 way for me yet.....
I have to check if one of the patches includes something that is related to pdo configuration, but i am on tour at the moment. Time is critical....
As for Saschas and my lcec drivers/components gaps have ever worked.
- Thank you received: 4153
4 years 5 months ago #244179
It is no longer necessary to do the etherlabmaster build process if you use the repository for etherlabmaster and install as I described here:
forum.linuxcnc.org/ethercat/45336-etherc...-how-to-step-by-step
I thought I read somewhere that the patches are no longer necessary as they have been rolled up into linuxcnc master branch or into etherlabmaster itself.
I have certainly not found it necessary to install the patches with the method in the sticky I linked to here.
Replied by rodw on topic "gaps" with 0x000 x00
I think the build process for etherlabmaster is obsolete and needs to be ignored. It certainly does not work with Debian 11 and on. It follows the old etherlabmaster repository before they transitioned from mercurial to gitlab. How can it be safe to use?if you install etherlab with ec-debianize, there will be applied some patches from sittner and an bigger patchset from gavin lambert.
Time to create page: 0.337 seconds
