- Configuring LinuxCNC
- Advanced Configuration
- EtherCAT
- Any recommendations for a mini PC for an EtherCAT setup?
- piflixe
- Thank you received: 5
23 Nov 2022 21:44 #257520
by piflixe
Replied by piflixe on topic Any recommendations for a mini PC for an EtherCAT setup?
In
this youtube video
the celeron J4125 got astonishing good realtime results.
- Thank you received: 4138
24 Nov 2022 09:25 #257548
I have never seen the GLUT error either. My guess is its an unsupported feature on Wayland graphics if you are using the default desktop. But its never been an issue for me.
On the logon screen, at the bottom right, you can select a different graphical environment if you installed one on installation.
If not, install xfce by typing: sudo tasksel and select it from the logon screen (you might need to sudo apt-get install taskselfirst)
This gives you the same environment on the linuxcnc ISO and uses Xwindows. You may need to select it from the logon screen.
(Tasksel might take a while... and I have no idea if this is a bum steer or not...)
Replied by rodw on topic Any recommendations for a mini PC for an EtherCAT setup?
Phew! I'm glad I did not sell you a bum steer!In this youtube video the celeron J4125 got astonishing good realtime results.
24 Nov 2022 11:45 #257555
Hmm, I upgraded my bookworm pc with
And I experienced the exact same behavoiur in the default graphical environment!
So I followed my own advice and installed xfce with tasksel and everything is perfect.
Just note you need to have your cursor in the password field and you will see a cog appear at bottom right, click on that to select xfce before logging in.
First time I've not been able to run linuxcnc on the default Wayland Debian graphical environment.
sudo apt-get update sudo apt-get ugradeAnd I experienced the exact same behavoiur in the default graphical environment!
The following user(s) said Thank You: mwc
- mwc
- Thank you received: 9
24 Nov 2022 18:06 - 24 Nov 2022 18:08 #257568
by mwc
Replied by mwc on topic Any recommendations for a mini PC for an EtherCAT setup?
Installing and changing to xfce now allows LinuxCNC to load, however in Gmocapy and GScreen, the graphics (machine plots) are just blank.
Axis loads OK with no errors.
A scan of the terminal output, it seems like there's still something missing, or something not the correct version.
I've attached the terminal outputs (I did try pasting them in as code, but I get a too many links error when trying to post with the output in the forum post).
If nobody has any more suggestions, I'm thinking I might do a clean install, but stick to Bullseye.
Last edit: 24 Nov 2022 18:08 by mwc.
- leexi
18 Apr 2023 06:02 - 18 Apr 2023 06:33 #269352
by leexi
Replied by leexi on topic Any recommendations for a mini PC for an EtherCAT setup?
I am thinking to purchase . any advice,
I am looking it just for worth the price and industrial casse.
to be used on ethercat net 3 stepper drive and io-box on linuxcnc 2.8.4
this is a pcbox Intel Celeron J6412, 4 cores 4 threads, 1.5M L2 Cache, 2.0GHz, up to 2.60GHz
link.
www.aliexpress.us/item/2251832646600184....apt&_randl_shipto=US
link.
Last edit: 18 Apr 2023 06:33 by leexi. Reason: to complete
18 Apr 2023 07:41 #269359
I have used a similar PC and it should be ok but there are some tricks I have just got to the bottom of.
1, Install Bookworm
2. Install my 6.3 kernel (improves PC latency by 265%)
3. Install the R8168-dkms driver given the PC uses R8111 NIC's (improves network latency by 400%)
follow these instructions as it covers all of this...
docs.google.com/document/d/1jeV_4VKzVmOI...diY/edit?usp=sharing
1, Install Bookworm
The following user(s) said Thank You: leexi
- EtherCAT
Time to create page: 1.112 seconds
