mint 21 or 20 suggestion ...
- bkt
- Thank you received: 114
21 Nov 2022 12:25 #257208
by bkt
mint 21 or 20 suggestion ... was created by bkt
Because mint/ubuntu lover i search the best distro for new rt-kernel.
Someone can suggest me best last rt-kernel for ethrcat + mint xx??
I install over H210 and I5-7500 ....
best regards
best regards
- Thank you received: 7453
21 Nov 2022 15:31 #257227
Replied by tommylight on topic mint 21 or 20 suggestion ...
I use Mint 21 with 6.0.2 Debian RT kernel.
I do not use ethercat.
The new kernels have issues with Realtek network cards, so check that before jumping to new kernels.
The following user(s) said Thank You: bkt
- Thank you received: 4128
21 Nov 2022 20:00 #257252
Replied by rodw on topic mint 21 or 20 suggestion ...
Tommy is right.
I don't think ethercat is affected by the realtek card causing excessive network latency like the mesa cards
Just follow my sticky to install ethercat for Debian Bookworm (I think). This should get the right ethercat distro for kernel 6.0
- bkt
28 Nov 2022 17:02 #257867
by bkt
Replied by bkt on topic mint 21 or 20 suggestion ...
so your suggestion was for Mint20 + kernel 6.0 + ethercat? .... using kernel 5.x??
bkt
bkt
28 Nov 2022 17:24 #257871
Mint 20 does not work with LinuxCNC 2.9 due to Python related issues.
It does compile and run without issues though, just not using the ready made debs.
Time to create page: 0.668 seconds
